Sensor in the head (pass side)
Old Aug 29, 2009 | 10:42 AM
bowtieboy42's Avatar
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Ive been trying to diagnose my idle/stalling problem, and just thought of something. There is a hole for a sensor to go on my left (edit: Right) head. I found a melter sensor dangling under the car. What sensor should go here, and does it effect idle? Thanks
Old Aug 29, 2009 | 11:36 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Sensor in the head (pass side)
Coolant temp sensor for the dash gauge.
Old Aug 29, 2009 | 11:45 AM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
I thought that was the sensor in the driver side head? Or does the car have 2?
Old Aug 29, 2009 | 12:05 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
The drivers side is the left side. On the right side (pass.) head you have a coolant temp. sensor and below that sensor is your knock sensor.
Old Aug 29, 2009 | 12:28 PM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
I'm sorry. I have the sensor in on the driver side, but the pass side is missing its sensor. So its the coolant temp im missing? I have a temp readout on my gauges...
Old Aug 29, 2009 | 01:17 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The pass side sensor is actually a temp switch that controls operation of the radiator fans. Won't affect idle but should be fixed so that your fans come on with engine temp.
Old Aug 29, 2009 | 05:05 PM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Do you know what the name of this switch is so I can buy a new one?
Old Aug 29, 2009 | 08:41 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Rock auto calls it a cooling fan controller. Any auto parts store should have it, just ask for a cooling fan switch. Just curious, but how are you runnung your engine with a hole in the head where this switch goes without spewing coolant all over?
Old Aug 29, 2009 | 08:54 PM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
I'm really not sure, but I'm not.
I know the PO jump wired the fans so they both come on at the same time, but I figure I'll pick up the switch anyway. thanks!
Old Aug 29, 2009 | 08:58 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
thats interesting.... I'm missing them both... huh
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 5, 2015 11:57 PM
