Corrected Timing and Runs Worse
Old Sep 15, 2009 | 09:49 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I corrected the timing on my 1986 305 tpi, and it now seems to have less power than before, and the engine cranks longer before it starts now, too. Everything else is adjusted correctly, too (tps, iac), and the car feels quite a bit more sluggish. I set my timing light to 6* and set the distributor cap so the timing mark is right in the center of the largest "V" valley, and I unplugged the brown wire on the passenger side near the firewall, before I checked and set the timing. I don't get why it has less power now and also is slower to start up, when the timing is set to the correct * btdc. Weird.
Old Sep 15, 2009 | 11:27 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: Changed Timing and Runs Worse
It seems like I should just advance it back to where it was, right around 7-8 degrees btdc.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
