tpi issues. quick help appreciated
Old Oct 21, 2009 | 07:37 PM
kylehorn09's Avatar
Car: 87 Trans Am GTA
Transmission: 700 R4
I have an 87' Trans Am GTA. 350 TPI, auto trans.
heres my issue. The car starts. But has a really rough idle. really rough. And when i push the gas or move the throttle body just the slightest bit. it acts like it wants to die. needless to say. i haven't been out in 2 days. it has done this before but only for a minute or two then it was fine. I checked for loose/cracked/ripped vacuum hoses; none. Took out all the spark plugs, they're all fine. My uncle said i should tap on the mass air flow sensor when it's running and see if anything happens. nothing happened. I just bought this car. any suggestions?? Thanks in advance
Old Oct 21, 2009 | 07:38 PM
kylehorn09's Avatar
Re: tpi issues. quick help appreciated
Forgot to add, but i can get it to rev up if i pump it a couple times or hold it open for a couple seconds and it will all the sudden rev up. also, while trying to do that. i'm pretty sure i heard and felt it backfire through the intake.
Old Oct 21, 2009 | 07:44 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
does it have any codes??
Old Oct 21, 2009 | 08:04 PM
kylehorn09's Avatar
if it does, i dont know how to get them. ? and i think the service engine light is burnt out. cause it's never come on.
Old Oct 21, 2009 | 08:07 PM
Engine: 383 hsr
well if its burned out, just pull the dash bezal off and throw a new bulb in. but if you just turn the key to on, without starting it, the check engine light should be on. if it isnt, then like i said just replace the bulb.
Old Oct 21, 2009 | 08:11 PM
2c2g's Avatar
Car: 88 trans am
Engine: 305 tpi
I've got the same problem with my 88 i unplugged the maf and it allows the engine to idle smoothly but at 1100( to high) and drops down to to 750 when i put in gear, but it run like crap at highway speed .Does anyone know if this is a bad maf or what else is causing the extremely rough idle?will a odb 1 scanner help diagnose this problem?
Old Oct 21, 2009 | 08:12 PM
kylehorn09's Avatar
god....lol that is gonna take forever. luckily i dont work tomorrow. haha
Old Oct 21, 2009 | 08:14 PM
Engine: 383 hsr
i can help you guys, but im trying to do a process of elimination. FIRST being, what codes do you have?? after you tell me that, then i can start throwing suggestions and more advice. so first things first.
kylehorn09's Avatar
mine idled at 1000 now that i think about it. now its way down into like 600-900, but really really rought.
Old Oct 22, 2009 | 08:48 PM
kmd's Avatar
kmd
i just had the same problem with my 88 camaro. i cleaned off my IAC and it actually runs now. my problem was a combination of bad ignition timing and the IAC, i don't know if that's the same issue with yours but maybe it'll give you somewhere to start.
Old Oct 23, 2009 | 01:19 PM
kylehorn09's Avatar
well it seems as though i solved my problem. it was the maf. I got to looking around about bad mass air flow sensors. and ended up on an audi site lol. they were tellin some guy to start the car with the maf disconnected and if it ran better that was the problem. well...i thought wat the hell, so i did it. thinking the car wouldn't even start. but it did, and it ran better. so i had an extra maf at a buddies house. replaced it. and the car runs. no reall rough idle. or anything. also, i saw that on the maf i took out of the car it had the engine side screen taken off on it. maybe that was a contributing factor? also, can anyone tell me how to properly drop the idle on my car. it idles around 1000-900 rpm. any help is appreciated.
Old Oct 24, 2009 | 01:49 PM
Engine: 383 hsr
can anyone tell me how to properly drop the idle on my car. it idles around 1000-900 rpm. any help is appreciated. [/quote]
thats normal....
Old Oct 24, 2009 | 05:44 PM
kylehorn09's Avatar
thats normal....[/quote]
i know its not supposed to be that. hi. maybe minimum idle speed should be around 650-600. warm up idle should be that. but i got it dropped. the right way. here is a link. this is after you hve determined you have no vacuum leaks, and you have set your time.
http://www.hotrodhandbooks.com.au/eB...Line-11-5.html
Old Oct 25, 2009 | 02:18 AM
Engine: 383 hsr
Man I'm not tryin to be a **** or anything but a 1,000 rpm is generaly the desired rpm for ALL cars. Mine runs that too and it's just great. Yeah there are a few cars that may run a lowwer idle and with cam change, higher. Usually. Too low of an idle affects oil pressure alot, which MAY not matter but it would worry me...
Old Oct 25, 2009 | 04:20 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
IAC and TPS Adjustment,
https://www.thirdgen.org/tpimod2
Old Oct 25, 2009 | 05:01 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The baseline idle of 450 is just a reference point for the ECM. The ECM actually takes control of the engine at 400rpm taking into account all the the other parameters like temp, load, battery voltage...etc, and the Desired RPM versus Temp table in the EPROM.
My 383 starts around 900-1000rpm and almost immediately settles down to 700-850rpm, the higher the coolant temp the lower the idle rpm.
The Minimum air rate procedure in the 700r4 link is the same as in the manual. You'd think this site would have the same information in it's IAC tech article, but it doesn't.
I would also suggest for the procedure the use of a scanner, TunerCat, TunerPro, or similar program, or a precision tach because the OEM tach when new was at best reasonably accurate, unfortunately it does degrade overtime. So, if you use it to set your idle it mostly likely won't be correct.
Old Oct 26, 2009 | 10:30 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
600-650 rpm's is where it should be on a V8!!! STOCK!
And about 400-450 rpm's in DRIVE and foot on brake.
Old Oct 26, 2009 | 10:42 PM
Car: 87 T-Top GTA
At 450-500 rpm's my oil pressure sits at 350 kpa.....at that high amount of pressure, I'm not worried at all!
NBrehm
Aug 25, 2015 11:49 PM
crazynights
Aug 21, 2015 06:53 AM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
