350TPI motors
Old Nov 6, 2009 | 11:52 PM
tanda10506's Avatar
350TPI motors
Hello. I have built alot of old school SBC motors and LS1's but I just bought my first 3rd Gen. It has the 305TBI and Im going to be swapping that. There is alot of info on this forum for that. But one thing that I heard that I can't find anymore info on is that, from what I'm told, the 350TPI long blocks are the same as the older small block chevys. And that I can use an older block and set of heads and just bolt up the TPI equipment. Is this true?
Old Nov 7, 2009 | 02:23 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 350TPI motors
Well, yes and no. Yes, TPI is still a gen1 engine, although there are some minor differences between years. As far as factory TPI engines, 87+ had a slightly different intake, for centerbolt heads. The four inner intake bolts go into the heads at slightly different angles than the others. So, if you're using pre-87 heads, you'll need a lower intake from an 85 or 86 TPI setup.
Old Nov 7, 2009 | 04:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350TPI motors
Only on TPI 's from cast iron heads .The vette alum head L98's used the regular SBC (90 degree ) bolt angle on all 85 -91
Old Nov 7, 2009 | 04:16 PM
tanda10506's Avatar
Re: 350TPI motors
What about aftermarket small block chevy heads then?
Old Nov 7, 2009 | 06:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 350TPI motors
Unless they are noted as a direct replacement for the '86+ cast iron heads (centerbolt covers ) all SBC heads have the regular bolt angle dating back to 1955.
At worst case if you get a intake of a late cast head engine it is only a matter of elongating the centerbolts holes to make it fit the regular heads.Many have done it
The only intake that is not a bolt on without major mods is the LT1 intake
Old Nov 7, 2009 | 06:26 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: 350TPI motors
almost all aftermarket SBC heads use the Pre 87 bolt pattern, some use the vortec pattern (8 bolts total, all straight up and down).
Old Nov 7, 2009 | 10:01 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 350TPI motors
In which you are up for a different intake base ( $400 ) as the regular TPI base does not fit Vortec heads
Old Nov 8, 2009 | 11:07 AM
tanda10506's Avatar
Re: 350TPI motors
Ok. After some researche, I decided I am going to use a 88 Chevy Truck 350 block and stroke it. So if I get an aftermarket set of aluminum heads that are for centerbolt valve covers then the TPI intake will bolt right up to them then?
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
slade5612
Aug 11, 2015 07:19 PM
