Bad throttle body?
Old Nov 8, 2009 | 06:13 PM
tpi305's Avatar
Car: 1986 Iroc-Z, 1980 Cadillac Eldorado
Engine: Iroc- 5.0, Caddy-5.7
Bad throttle body?
I was looking at my throttle body today on my 86 Iroc and I noticed that the return spring on the side where the throttle cable hooks up to it looks to be kind of "unwound." The place where the spring is mounted is kinda loose and wiggly as well. Is my throttle body shot? Is that why I've been having trouble with the idle and why when I stop, it'll idle at 1000 until I just tap the gas extremely lightly? I adjusted the tps and the iac is new. Thanks.
Is there any way to fix it or do I need to replace the whole unit? If I do, is a 52mm safe?
Old Nov 8, 2009 | 07:44 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: Bad throttle body?
Yes it is shot, just go to a junk yard and get a stock style one. when i went i found a 58mm and got it for 40 bucks and made my car run like crap so i went back and got a stock one. stay stock it flows plenty.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
