tpi to lt1 intake
Old Nov 10, 2009 | 12:45 PM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
tpi to lt1 intake
who has done it and how hard is it to do???
would it be more cost effective to just buy a hsr and just use that???
Old Nov 10, 2009 | 05:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi to lt1 intake
https://www.thirdgen.org/forums/tpi/...e-350-tpi.html
Old Nov 10, 2009 | 08:34 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
thanks for the links it seems a lot harder than its worth and can be expensive as well..i think i am going to start looking for a hsr
Old Nov 10, 2009 | 08:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It is doable on the cheap if you have access to the tools and can do the work yourself.If you have to pay for the work then $600 HSR starts looking a better bolt on option.
Either option you are up for custom fuel lines and a small cap dist/ remote coil if you don't already have
Old Nov 10, 2009 | 08:43 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
i think it would be wayyy cheaper to do the lt1 swap than an hsr. the way i think of it is, Man up and do some work with your hands to get the lt1 to work, and save a butt load of money, or be an idiot and spend 3000 on an intake.
Your call lol
Old Nov 10, 2009 | 08:59 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
i can find a hsr with fuel rail for less thank 1000 maybe even less than 800 but thats direct bolt on isnt it???
just have to mod the hsr to fit my hei coil
but with the lt1 intake i need a remote tstat,new throttle cable plus the price of the intake and all the machine work that has to be done i couldnt imagine it being much less than the hsr...
Old Nov 10, 2009 | 09:04 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
ive seen the stealth rams modded to work with the hei so i will just do that fuel lines are no big deal
how hard is it to put a small cap distributor in place of the hei if i have a 6al and blaster coil already installed in my car....
Old Nov 10, 2009 | 09:16 PM
Engine: 350 Tpi
Axle/Gears: 3.08
how much is an lt1 intake off a caprice or somethin at the junkyard? 100 bucks? just drill your own bolt holes, weld in the dizzy hole, weld the coolant return ****. block and disable egr, remote t-stat. just put on the fuel rail, and injectors that came with the lt1. and then the afpr.
i dunno i just think the lt1 intake is definitely the way to go. Im almost sure that a ported lt1 intake will flow just as good or better than the hsr intake. Am i right? correct me if im wrong.
Old Nov 10, 2009 | 09:26 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
easier said then done bro especially when my tool list consists of a socket set and a cordless drill...and thats it...i dont have the time or means to go fabricating up an lt1 intake to work with my car....the hsr with fuel rail can be had for just over 500 new...and it bolts right on
Old Nov 10, 2009 | 09:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Sounds good but engineering has to be fairly precise otherwise it will leak like a sieve
HSR flows 275 out of the box.
LTI needs some work ($$$) to get that
Old Nov 10, 2009 | 09:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
ive seen the stealth rams modded to work with the hei so i will just do that fuel lines are no big deal .
You sure ? HEI can be made to fit but you can't turn to adjust timing. Only way to get HEI on HSR is cut and weld rear for clearance which no one does.
Drop in swap with $15 HEI to small cap adapter harness and a $10 dist connector for the remote coil.
Email Mike (S10Wildside on here) at EFI Connection to set you up
http://www.eficonnection.com/eficonn..._pigtails.aspx
Old Nov 11, 2009 | 01:09 AM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
i dont understand that at all...i dont want to have to pull apart all my wiring either...it was a pain in the *** to wire up all the msd stuff on that distributor...
is there any write ups any where on how to do the distributor swap???
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
