86 iroc cold air intake
Old Nov 16, 2009 | 03:29 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I am looking for a cold air intake for an 86 iroc 305 tpi, any suggestions?
Old Nov 16, 2009 | 06:12 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 86 iroc cold air intake
do a search
Old Nov 16, 2009 | 06:23 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
make one!
Old Nov 16, 2009 | 06:33 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i got mine from slp a few years back. for my 86 305tpi iroc. i had to relocate my battery to my driver side though.
Old Nov 17, 2009 | 06:14 PM
Engine: V8 305
where would i get one of those cone ones that just snap on the end without all the tubing and battery location?
Old Nov 18, 2009 | 10:45 AM
Engine: V8 305
bump
Old Nov 18, 2009 | 11:31 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
thats not a cold air intake, that would be a low restriction hot air intake. The intake you already have is a cold air intake. If you want to cut the baffles under the air box, that would be your best bet. What other mods have you done to your car
Old Nov 18, 2009 | 11:57 AM
Engine: V8 305
https://www.thirdgen.org/forums/au...-new-86-a.html
A link to some car pics. She has a flowmaster catback exhaust and she is lowered, not sure what engine mods, if any.
Old Nov 18, 2009 | 12:28 PM
Shadow Z's Avatar
Car: Lots of 'em
I've been wanting to do this for a while. I started thinking about it because I have a carb'd 350, and the only real cold air intakes for them look like a barrel with octopus legs coming out of it.
I realize you have fuel injection, but where I'm going with this is that you can easily make your own, it's pretty straight forward.
Or, here you go.
http://www.knfilters.com/universal/apollo.htm
My plan is to just buy a carb hat from Steve Morris Racing engines and run the Vararam Tri Power, it would work nicely with my Camaro, since the tubing is flexible. I think mounting it behind or to the side of the fog lights would be a good position, so I don't pick up much debris, well, none I hope.
It's all up to you, you have basically limitless options, custom fabrication isn't hard at all when there's flexible tubing.
Hope this helps!
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
