need help any positive info appreciated
Old Nov 21, 2009 | 12:06 AM
dirtyd6669's Avatar
Car: 87 Trans Am
okay heres the problem sometimes when i drive the car it will run great for 30 mins then other times when i push the gas past 1500 rpms it doesnt really want to accelerate it accels very slow. if i push it to the floor the rpm's wont get above 2000 but it still accelerates very slow i think i saw a turtle pass me when i tried to accel. Let me know what you think might be causeing this.
I am also getting code 33 but i dont need the trouble code proceedure as i have the factory service manual for my car. i have followed the wires under the hood and havent found any bad wires yet i pulled out the back seat and followed the wires to the fuel pump and they seem fine.
Now for what i have done i replaced the alt cause it wasnt charging, replaced 2 out of three relays but when i change the maf power i get a different code and it wont run but maybe for a min if that. replaced the fuel filter, and bought a used maf air flow sensor and put that in. im going to replace the ends to the grounds on the back of the head in the morning and the plugs and wires.
i think its a 305 but i do know its tpi trans am
Old Nov 21, 2009 | 12:10 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: need help any positive info appreciated
Sounds like your on the right track it could be the plugs are fouled.
Old Nov 21, 2009 | 03:32 PM
dirtyd6669's Avatar
Car: 87 Trans Am
Changed the spark plugs and wires, checked the grounds on the back of the motor and they were fine, i also noticed the starter wires were loose so i tighted the nut. i am still having the same problem any ideas of what else i should check..... Could the trans be causing this problem. Oh and im still getting code 33 too but on monday im going to take the dash out and see if there are any bad wires in there.
Old Nov 21, 2009 | 03:39 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Still have a catalytic converter in there? Might be plugged. (and would give odd MAF readings as well)
Old Nov 21, 2009 | 04:07 PM
dirtyd6669's Avatar
Car: 87 Trans Am
yeah i still got the catalytic converter how would i check it to see if its clogged
Old Nov 21, 2009 | 04:52 PM
ploegi's Avatar
Engine: 5.7 TPI
Disconnect the cat from the downpipe, and take the car for a test drive. (yes, it will be a bit on the loud side, but, I have to say, it sounds REALLY good like that.......) Be sure and secure the exhaust pipe so it wont hit the ground, and drag..... that could be very bad.
Other alternative would be to drill a small hole in the exhaust BEFORE the cat, and watch the pressure. Normally, at idle, it should be less than 2PSI.
You can also rap on the cat with a hammer, and if you hear it rattling, time for a new one. (don't hit it too hard....... you aren't trying to drive nails here.)
Old Nov 21, 2009 | 05:53 PM
dirtyd6669's Avatar
Car: 87 Trans Am
okay i will also do that on monday and after i did everything to it today i drove it and when i pushed the gas to the floor it would rev up to 3000 rpm's but still didnt wnt to move but anything i do to it i will post on here so that it will hopefully narow down the problem
Old Nov 22, 2009 | 12:40 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Nah bro. My camaro just wouldnt rev. up during park or in drive. Sounds like your MAF Sensor is going bad. To test the MAF Sensor, follow link https://www.thirdgen.org/forums/tpi/...uble-code.html
Old Nov 23, 2009 | 11:37 PM
dirtyd6669's Avatar
Car: 87 Trans Am
any more suggestions for you guys out there
Old Nov 23, 2009 | 11:49 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
check your fuel pressure
Old Nov 24, 2009 | 10:09 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
check your tps, also what year is the car?
While the motor is idleing lightly tap on the mas with a screwdriver if the motor stumbles then the problem is somewhere in the mas circuit
Old Nov 25, 2009 | 07:30 PM
dirtyd6669's Avatar
Car: 87 Trans Am
its am 87 trans am with the f in the vin but the book i got says it should be a MPFI but its a TPI setup. Should i check the voltage on the tps and how do i do that the factory service manual i have is very confusing but i will figure out how to read the book
Old Nov 25, 2009 | 09:00 PM
MPFI but it's a TPI. dirtyd6669, Your setup is a TPI (Tuned Port Injection) right? MPFI means "Multi-Port Fuel Injection". In other words, the fuel is injected into its very own individual port. If you compare a Throttlebody Injection unit that are found in the Camaro RS's, you'll see that there are 2 injectors that spray fuel into the intake which divides the air fuel mixture into the "Spider intake" much like the carburated unit intake. Now if you look at the setup on your "TPI" you'll notice that each intake runner goes down and crosses over into the opposite side of the block. Now before the air dumps into the intake valve/port, there is a fuel injector that is specifically for that individual port. Now thats why it is called "Multi-Port Fuel Injected." Eight individual intake ports with 8 individual fuel injectors, hench "MPFI." So next time some asks what kind of setup you got, you should say "87 trans am with a TPI setup, Multi Port Fuel Injection V8 350 OR 305 engine."
redmaroz
Apr 25, 2017 07:14 AM
Americanmouse
Sep 7, 2015 12:10 PM
ambainb
Aug 29, 2015 12:43 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
