305 TBI to 350 TPI
Old Dec 12, 2009 | 01:29 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
305 TBI to 350 TPI
I have a 91 firebird base model it has a 305 TBI and recently accuired a l98 from a 92 z28 and am looking to do the swap...in short its going to be a mainly stock swap with headers. I might how ever do a mild cam, one the stock valve train could handel. basicly im looking to make the swap as "simpel" as posibel. so i have a few questions.(please refrain from references to building up the stock rear or stock tranny these are issues im aware of and will take up later)
1.) First off will i need a new fuel pump? How about fuel lines?
2.) Would I be abel to pull the ECU from the car along with the engine harnes and put a ECU from 90-92 350?(I would do this to make re wiring the new 350 easyer)
Thank you guys for your time...im not decided on what im going to do yet im still playing with ideas like going carb or a holley TBI if i can find one for cheap.im looking to find a happy medium between cost and power
Old Dec 13, 2009 | 01:49 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
Re: 305 TBI to 350 TPI
no one has any imput?
Old Dec 13, 2009 | 03:45 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
1. yes. no.
2. yes, if you whant the TPI
It will take a lot more then cam and exhaust, untill rearend and tranny need to be upgraded.
Old Dec 13, 2009 | 07:21 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
thanx....so do you think that would make wiring easyer
Old Dec 14, 2009 | 08:11 AM
thomas1976's Avatar
Car: 91 Trans am
I would say for 99.9% of us its a must if switching to TPI. The dual fan could be cool to since its already set up in the 92 TPI harness and ECM.
If you slap the TBI on the L98 longblock, keep the TBI harness. EBL will make the tuning easy and efficient.
Old Dec 14, 2009 | 04:26 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
does enything eles besides the engine harnses plug in to the ECU....if so will the stuff in the car now work considering its from the "Same" car(meaning it was an option to get this enigen in my year)
Old Dec 14, 2009 | 04:47 PM
thomas1976's Avatar
Car: 91 Trans am
TCC and VSS for sure, but is it part of the engine harness? I know there is a tgo thech article covering TBI to TPI swap.
If you are too lazy to look at your car, engines, harnesses, ECM's, find a service manual or search tgo's write up, maybe you should just leave it.
Old Dec 14, 2009 | 05:13 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
yea that article from what i got you re pin the TBI harnese and take parts form a TPI harnese to make a new one....i would get under the dash and look but im in NY and its been shitty out and when i get home from work its dark
Old Dec 14, 2009 | 05:25 PM
thomas1976's Avatar
Car: 91 Trans am
https://www.thirdgen.org/tbitotpi
http://tpiparts.net/1227730_pinout_diagram
Personally I would not consider adapting the TBI harness for TPI, as long as the TPI harnes can be found or purchased.
Old Dec 14, 2009 | 06:36 PM
fcukit33's Avatar
Car: 92 camaro rs
Engine: 305tbi
thanx man
Old May 12, 2014 | 08:16 AM
1991305tbi's Avatar
ok so for all that are confused like i have been through most of this if you go to an auto dismantler and buy a 350 tbi engine which is drop in and plug up and use with the 350 tbi on it all you need is the ecm (or ecu what ever you prefer to call it) to a 350. im going to get pricing on all of this today the dismantler has a 92 z-28 with ecu and 350 to pull and put in mine. please correct me if im wrong but im sure this would work essentially id be making my car into a 92 tbi z28
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
