Throtle Body By Pass For TPI?
Old Dec 13, 2009 | 09:13 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey Everyone,
Has anyone done this on a TPI? I seen the article here on the board but I believe thats for a LT1 throtle body.
If so could you post some pics for us.
Thanks. Tony.
Old Dec 13, 2009 | 11:33 PM
Engine: 3.0L 2JZGE
Re: Throtle Body By Pass For TPI?
Anyone?
Tony.
Old Dec 14, 2009 | 12:27 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
See below link, we have a tech article on it.
https://www.thirdgen.org/coolantbypass
Old Dec 14, 2009 | 04:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old Dec 14, 2009 | 03:40 PM
Engine: 3.0L 2JZGE
Yeah I seen it before but it looks like that throttle body is off the LT1's.
Tony.
Old Dec 14, 2009 | 03:41 PM
Engine: 3.0L 2JZGE
Originally Posted by vetteoz
Alright then i'm not sure what i'm looking at here on this pic.
Tony.
Old Dec 14, 2009 | 04:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Tony.
Makes no difference.There are two coolant lines going to the TB ; disconnect them and join hoses together .
Finished , done
If you want to make it look pretty you can cut the redundant spigots off the IAC housing as shown it pic above
Old Dec 14, 2009 | 09:31 PM
Engine: 3.0L 2JZGE
Finished , done
Thanks for the info but I dont get what you mean about making it look pretty like in the picture. Do you have a different pic that I couls look at?
Tony.
Old Dec 14, 2009 | 10:29 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I took off my hose. As for the nozzle that sticks out of the intake, if it's took hard to unscrew, then get a threader or tap and die ( not sure what it's called) and thread the inside of the nozzle., Then get a plumbing screw or bolt and srew it in to prevent the coolant from leaking out the intake manifold. Make sure to use that liquid teflon stuff to make a good seal. Confused? I can provide a picture tommorrow.
Old Dec 14, 2009 | 10:59 PM
Engine: 3.0L 2JZGE
A picture would be great.
Thanks. Tony.
Old Dec 14, 2009 | 11:34 PM
It may seem difficult to see the plug but you'll get the general idea. The circled plug is where the coolant leaves the intake manifold, then enters the bottom of the throttlebody, then leaves the throttlebody and goes into the heatercore. Let me know if you need more help.
Attached Thumbnails Throtle Body By Pass For TPI?-102_1147.jpg   Throtle Body By Pass For TPI?-102_1148.jpg   Throtle Body By Pass For TPI?-tpi-intake-fnt.jpg
Old Dec 14, 2009 | 11:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I took off my hose. ...., if it's took hard to unscrew, .
Too much work, just get a 5/8" rubber heater hose cap from NAPA and use a hose clamp to seal
Most people would reuse the nipple on the intake to hook their heater hose back up to
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
https://www.thirdgen.org/forums/tpi/...nt-bypass.html
Old Dec 14, 2009 | 11:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Look underneath your TB , there is a alum casting with the IAC valve on left and two water hoses.Compare that with the pic above
After you have done the bypass you can cut the water outlets off as nothing is going through them any more
Old Dec 14, 2009 | 11:59 PM
It is more work, but I had it done when I had the engine out (during rebuild stage). The plug can ealily be taken out. All I need is the proper Allen Wrench and Im good to go. I chose this method because I wasnt sure how long I was going to go without a heatercore. So I chose the plug over the heater hose, stud and clamp. But vetteoz is right. Either way, its under the throttlebody and barely even visible.
Old Dec 15, 2009 | 07:40 AM
Engine: 3.0L 2JZGE
Hey Chevy86 IROC-Z,
Thanks for the link a lot of great info, now im gonna go purchase a hose and just simply connect the too.
Thanks. Tony.
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
jbd1969
Aug 17, 2015 07:06 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
