Throttle Body size?
Old Dec 24, 2009 | 09:25 PM
jbates346's Avatar
Throttle Body size?
I feel stupid for asking this but does anybody know the stock/factory size throttle body for a '88 IROC LB9 (305 TPI)? I'm looking to get a new one soon and i wanna go bigger but i'm wondering what would be the best size to get. Has anybody put a couple on their LB9 and knows which size is better? 52or 58mm? Thanks for any help guys.
Old Dec 24, 2009 | 09:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Throttle Body size?
the factory size i believe its 48mm stock
Old Dec 24, 2009 | 09:49 PM
jbates346's Avatar
I wonder if a twin 58mm would be to big? Its pretty much a stock LB9 with headers
Old Dec 24, 2009 | 10:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need some good mods to go above stock 48mm on a 350
The GMPP RamJet 502 ci big block comes with the same 48mm TB so I wouldn't be wasting your $$$ with larger on a 305
Old Dec 24, 2009 | 10:43 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
48mm is stock. I have a 52mm on my car and it made no difference in performance. You would be better porting your plenum, smooth out the bumps inside. Once you build up the motor a bigger throttle body would be in order.
Old Dec 25, 2009 | 03:37 PM
jbates346's Avatar
Thanks for all the help guys. I'll hold off on the throttle body. Maybe look at something else.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
