Adding power to my 305?
Old Feb 2, 2010 | 01:49 AM
ThirdGenFire93's Avatar
Car: 1987 Firebird Trans Am
Engine: 305 TPI (68,XXX MILES!)
I'm looking to get some more power out of my 305 TPI, my goal is up around 250 horsepower.
Since the car is my daily driver.. I'm not planning on doing anything drastic, I'm thinking more along the lines of bolt ons and such.
I plan to buy some hooker headers (which ones do you guys reccomend?), the American Thunder Catback from Flowmaster, some high flow runners, and well.. I'm not to sure what else.
What do you guys think I should look into? Could you guys offer some links on what I should look into to get up around my goal? Having 250 HP sounds helluva lot better than having 190. Haha.
Thanks in advance guys.
Old Feb 2, 2010 | 07:53 AM
bigtgun3's Avatar
Car: 1987 Z28 Camaro
Engine: 305 TPI 5.0
Re: Adding power to my 305?
i would also like to know i have a 305tpi in my 87 camaro some links would be nice i know around what i would like to spend but if its to much of a hassel i could just 350 the car
Old Feb 2, 2010 | 08:28 AM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Well the trick is to open the engine up and let it breath.
I bought hedman headers and y-pipe for mine and they work great. The headers were #68470 and the y-pipe was #17470 and I bought em at Jegs. Well I took the smog pump off mine, but if you still have yours then go onto the jegs website and look around for some emissions type headers.
Then the catback like you were sayin and some better runners. After that I would look into an underdrive pulley. A guy on ebay sells a set of hawks racing ones that are cheap but still good quality.
Then a peformance chip would be a plus to help the engine better cope with opening it up. You can either buy one, Ive got a hypertech, or you can burn your own, if you wanna take the time to learn.
After that go get yourself a set of i think its 1.6 roller rocker tips.
Oh yeah, a cold air intake or something that opens the intake up will help too.
That should get you up there, I dont know if its quite 250 but it will be close, if i think of anything else ill let you know.
Old Feb 2, 2010 | 08:55 AM
Car: 92 Camaro RS
Engine: 305 TBI
Well if your lookin for some bolt ons for now to add a little power I wouldnt suggest throwin a bigger engine in, but if you wanna go past that 250 zone, buying a 350 would work out better.
Well your lookin at about $600 -$800, maybe less depending on if you can get the parts a little cheaper, to put everything I said in your car. The best thing is though, is that most of that will transfer over if you do decide to switch to a 350.
The cheapest and most gain dollar for dollar though would be to get a 350.
Old Feb 2, 2010 | 09:22 AM
bigtgun3's Avatar
Engine: 305 TPI 5.0
I have a 88 350 4bolt main i just need to find the time to swap the motor i was plaining on a 383 befro my money complcation but thanks for the info
Old Feb 2, 2010 | 10:37 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You need to change the cam and exhaust to get to 250 HP.
Old Feb 2, 2010 | 10:51 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Agreed... Cam and Exhaust... my 91 Formula 5.0 TPI 5 speed was close to that stock, because of the better cam and G92 dual cats...
With Hooker 2055 Headers & Y pipe, High Flow Cat, 3" catback, I'm sure it's at 250 or more... a chip and open up breathing (cold air) would also help...
Old Feb 2, 2010 | 12:08 PM
What cam should I look into getting than? :O
Old Feb 2, 2010 | 12:09 PM
Where could I get a cold air intake? I haven't seen any. And are installing the runners an easy thing to do?
Old Feb 2, 2010 | 12:22 PM
What headers could I get that are legal here in CA?
Old Feb 2, 2010 | 06:10 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
for a 305 and stock heads.. get the powermax 2032 cam.. one of the biggest cams you can get for your stock heads... its 214/220 452/465 on 112lsa.... sounded nice in my old l98 should sound lumpy in a 305...... noticed a buttload of torque off the line.. get the cam freshen up the heads with springs/retainers/guides/seals along with headers and exhaust and you should have your 250hp..
Old Feb 2, 2010 | 08:53 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Putting your car on the bottle is by far the quickest and easyest way to get to your 250hp goal. Not very practical tho.
Old Feb 2, 2010 | 09:09 PM
88fastgta's Avatar
i wouldnt nos any engine that old... too many problems can occur with an engine with that many miles... plus its only there when your using it.... to me nos is cheesy and kiddish to me..... most of my friends blew their engines using that stuff.... and im 21....
Old Feb 2, 2010 | 11:03 PM
thegooseman's Avatar
Car: 1992 RS
On my 305 that has 182,xxx miles I have SLP runners, Edelbrock baseplate, SLP 1 5/8 shorites with a Dyno Don y-pipe, car has been converted to duel cats, Magnaflow 3 inch catback. Got the car dynoed a couple weeks ago and I put down 198hp and 266tq to the wheels with the stock tune. I believe thats close to 250 hp and 330tq at the flywheel. I run 9.5's in the 1/8 mile with 2.77 gears and the car is smog legal. Hope this helps!
Old Feb 3, 2010 | 11:10 AM
mnorton's Avatar
Engine: 305 LB9 TPI
Hooker 2055's are C.A.R.B. approved.
Old Feb 3, 2010 | 12:04 PM
http://www.summitracing.com/parts/HOK-2460HKR/
Are these legal in CA?
Old Feb 3, 2010 | 02:45 PM
Car: 1992 RS
Nope! No air tubes. Go to Top down Solutions, their a sponsor on this site. Lon is selling Dyno Dons headers and y-pipes. Their 1 3/4, ceramic coated, and have all the emission stuff on there. Technicaly they dont have a C.A.R.B.# but all the high horsepower guys in cali are running them. You shouldnt have a problem at the smog shop unless the guy is a jerk.
Old Feb 3, 2010 | 08:10 PM
lb9 GTA's Avatar
All it would take is a 75hp shot to reach his goals wich is nothing on a 305 as long as its a wet shot. I've heard of a guy that ran a 250hp shot on a stock carbed 305. Mind you that was in his race car so he didn't care if he blew the engine or not. I'm not big on spray eather (seems almost like cheeting) however its cheep and easy to install. BTW I'm 22 and a mechanic
To answer some of ThirdGenFire93's questions. I'd recomend Edelbrock CES headers and y pipe. They're 50 stae smog leagle, flow well, and are a decent price. Stay away from the SLP CAI, all they are is a 200+ dollar air box. Your best bet is to get a 3" 45 degry and 90 degry peice of polished aluminum intake tubing and trim it to fit (if you go with Vibrint performance tubing there will be more than enough) with a high flow cone filter with 3" outlet. Up here each pipe is $25CND plus the cost of the filter. Make sure if you go this route you trim the radiator overflow outlet because, speeking from experiance, it will cut the overflow hose and dump coolant at operating temp. Flowmaster sounds good but I suggest a Magnaflow cat back because it flows much better. Also get a throttle body air foil. tou shouldn't need a lager throttle body with only 250hp.
Old Feb 4, 2010 | 12:20 AM
Originally Posted by lb9 GTA
I'd recomend Edelbrock CES headers and y pipe. .
Could you send me a link to where I could take a look at these?
Old Feb 4, 2010 | 05:21 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
CAI, catback, cam and headers should you get there.
Dont know if there are some decent heads beside the vette-heads
my mods:
Borla catback
custom cold air with airfoil
adj. fuel pressure regulator
Dyno: 251hp (204 rwhp)
Now added hedmann shorties and thinking about SLP runners and a custom tune.
Old Feb 4, 2010 | 05:59 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
When I had my 305, I put a cam, headers and flowmaster catback, K&N filters, removed airbox baffles, and drilled out airbox. I also put an MSD probillet dist. The dist really helped smoothout power throughout the entire rpm range. Another helpful cheap mod was removing the screen on the MAF sensor, and coolant bypass on the tpi.... All of these really helped the car make more power and breathe better...
Old Feb 4, 2010 | 09:53 AM
lb9 GTA's Avatar
http://www.hawksthirdgenparts.com/ed...dersystem.aspx I couldn't find them on Edelbrock's site tho. So it might be discontinued.
Old Feb 4, 2010 | 01:38 PM
Car: 1992 RS
Headers
http://www.top-downsolutions.com/pro...818c8a1b5aabbd
Y-pipe
http://www.top-downsolutions.com/pro...aeddee16661d1f
A thread about the quality and some pics
https://www.thirdgen.org/forums/exha...s-exhaust.html
Old Feb 11, 2010 | 03:09 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
subscribing to this. I have a stock 305 TPI that I'd like to squeeze a little more out of as well. Good luck with yours!
Old Feb 11, 2010 | 04:08 PM
Thanks alot for subbing. My car is up and running again as of today, new radiator
In three or four weeks my car shud be painted, looking new, then I can start with the performance upgrades. Atm im looking into a good set of hooker headers, and a possible cat-back. But I've heard that upgrading to three inch pipe isnt worth it?
Old Feb 11, 2010 | 04:23 PM
Engine: LB9
Really? that's weird. What's the stock exhaust pipe diameter in the 305 TPI cars?
Old Feb 11, 2010 | 04:31 PM
2.5 Inch.
Old Feb 11, 2010 | 04:39 PM
jgilbo17's Avatar
Car: 1991 trans am
Engine: LB9 tpi
nitrous is best used at less than half of what the motor makes naturaly, unless your realy experienced in tuning with it than go more, that being said if your car makes 200hp na then you at the most wold use 100 shot,
most people that are dumb and watch that fast and fuggin furious take a motor that makes 200hp and his it with a double shot of 300 and brag they got 500 horse then the first time they spray it they melt down, nitrous isnt kiddish its just another performance part that takes understanding to use, if nitrous is cheesy so then are turbos and blowers, not trying to **** any body off just my opinion
Old Feb 11, 2010 | 09:29 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
in my opinion it is better better flow less restriction and will sound a lot better than the factory exhaust... I am on the same quest as you this week i just put in a new fuel pump, new injectors (19lbs ford racing), adjustable fuel pressure regulator from BBK (feels like it made a pretty good increase in power as well torque) I just purchased a Magnaflow 3in cat back exhaust off of summit as well the Magnaflow cat to compliment the exhaust system and the headers I am getting next week which are the Edelbrock 68722 off of Summit. I would suggest doing mods like these to get a tad bit more outta the car itself and the next mod for me is a LT1 cam and vortec heads.
Old Feb 12, 2010 | 10:41 AM
Car: '91 Z28
Engine: LB9
Originally Posted by Brendan91Z
... and vortec heads.
youre aware that you need the SDPC-base manifold for the vortec heads or am I wrong
Old Feb 12, 2010 | 11:56 AM
Brendan91Z's Avatar
Axle/Gears: Stock
I am pretty sure summit has direct bolt on Vortec heads for the 305s I looked like a million years ago but i was pretty sure hey i may be wrong lol
Old Feb 12, 2010 | 02:42 PM
I always thought that three inch sounded alot better, I figure I will go with that then. What cat back do you guys think I should get? Best for the buck? OH and um, what Cat can I get thats legal in CA? Would this one work?
http://www.autoanything.com/exhausts-mufflers/61A3993A0A0A3099723.aspx
And it asks me if I have the code H engine or the code F engine, Im assuming one is for TPI and one is for TBI. Which code specifies TPI?
Old Feb 12, 2010 | 03:05 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
n2o will be the cheapest. all the ****in myths out there came from those damn movies. Run a cheap single nozzle setup, pull timing and run a colder plug.
Old Feb 12, 2010 | 08:44 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
What you are looking for is basically what I put together. I made 226 rwhp and 290 rwtq. On a manual transmission thats about 260 flywheel Hp and about 330 ftlbs of torque. I have a ported/seimesed plenum and base and ported and patially seimesed SLP runners, descreened maf, gutted airbox, Edelbrock headers, flomaster Y pipe, pully kit, Loud mouth Cat back, three inch from the Y pipe to the muffler, 1.6 roller tip rockers, apr, custom chip tune, and right at 300,000 miles on the engine/car. I am running a T56 trans. To get the power you want I really believe that what I have done is about as far as you can go with out changing the cam or the heads. ONe day I may do a 350 but I am satisfied with the way it drives for now. It finally makes enough power to keep up with at least some of the new cars.
I have gone from being down on the 305 to being very happy with it. I plan to take it to the track again this spring. No predictions but I am hoping for the high 13's. I do believe it can be done.
Old Oct 16, 2012 | 12:39 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I know this is an old thread but I think it's a good one.
The best seat of the pants upgrade is rear gears. I have gone from 2.77 to 3.73 and Jeez it flies!
Is the powermax cam still considered the one to go for? Is it computer friendly? Just seems so expensive still, would love to do the cam at some point.
Old Nov 7, 2012 | 08:16 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
(subscribed)
Old Nov 8, 2012 | 12:54 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
NO!!! Vortec heads require a vortec-pattern intake from SDPC or Edel-broke. The heads are OK, but that intake base doesn't flow any better than the stock one, so you are just moving the bottleneck and spending a lot of money to do it. I am also skeptical that the 350 vortec valve sizes will fit in the smallish 3.736 305 bores.
Also, I would not recommend the Edel-broke headers. Having had a set, they are also a poor design and I believe they are no longer in production anyway. Hooker 2055s are fine for a 305 on a budget, but Dyno Dons are the best.
TA
Old Nov 12, 2012 | 10:12 PM
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
do all the bolt ons and suspension, then upgrade to a 383
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
