Black Oil like stuff coming out of tail pipes
Old Feb 2, 2010 | 04:04 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so when i revv up my GTA too like...4 or 5k it shoots out this black powder stuff but its kinda moist and oil like...stained my parents drive way too oops...so what could it be? maybe to rich??
Old Feb 3, 2010 | 04:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Black Oil like stuff coming out of tail pipes
Most likely soot from an overly rich condition.
Old Apr 27, 2010 | 11:21 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
i forgot about this thread
anyway..so do i just get it retuned?
Old Apr 27, 2010 | 04:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Datalogging would be the first thing you should do.
You need to see what your BLM's, INT's, and O2 sensor are reading.
Old Apr 28, 2010 | 01:51 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
how would i go about doing that?
Old Apr 28, 2010 | 05:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Get ahold of Dyno Don and let him data log your car.
Old Apr 28, 2010 | 09:46 PM
Guest
Guest
Posts: n/a
Some is completely normal, especially if the car has been sitting and theres still a fair bit of water coming out the exhaust from condensation.
Old Apr 29, 2010 | 11:04 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
should water always be coming out??
Old Apr 29, 2010 | 11:22 AM
Car: 1989 GTA
Engine: 369 TPI
Mine does most of the time when cool.
Old Apr 29, 2010 | 11:34 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
My '86 Plymouth does that when the choke gets stuck, more fuel than air.
Old Apr 29, 2010 | 12:31 PM
Guest
Guest
Posts: n/a
Part of the composition of the exhaust is water, usually there is more on a vehicle with a cat.
Old Apr 29, 2010 | 07:11 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Staining of the driveway usually indicates a rich condition.
I actually had to use gas on my garage floor to clean up my mess. I found that all 8 of my injectors were stuck open.
I guess there's a legitimate reason for the washers that go between the fuel rail and bigmouth intake.
Old Apr 29, 2010 | 11:04 PM
TRANSAMCRAZY's Avatar
Car: 87 T/A,92 T/A,
Engine: 406TPI,355TPI,
Transmission: 700R4 for all
Axle/Gears: 4.11,3.23,
bad knock sensor, it controls the timing especally over 4k
Old Apr 30, 2010 | 02:43 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...alright. what about the o2 sensor??
Old Apr 30, 2010 | 03:24 PM
thedrewdotcom's Avatar
Car: 1986 IROC
make sure your injectors don't leak, is it misfiring?
Old Apr 30, 2010 | 03:28 PM
rockstar08's Avatar
Car: IROC-Z
Had exactly the same problem with mine when I bought it, I was getting 8 miles per gallon too LOL.. i've still got the stains on my garage wall!
Could be a rusty old muffler, give it a shake if it rattles, replace it.. but most probably a high rich condition, so plugs, distributor rotor and cap, with wires are usually suspect.. start with the plugs.. I'd also check the resistance over the fuel injectors, they should all be the same.. and check the o2 sensor, which will put the computer in open loop if it thinks the sensor is lying to it.
There's a great vid on youtube for testing an o2 sensor
http://www.youtube.com/watch?v=vdn4Dk5PSwc
How quickly does it come up to temperature? an excessively rich A/F condition made my iroc-z hover around 110deg forever..
Old Apr 30, 2010 | 04:07 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
ok...i was gonna change my plugs soon anyways.
and no it gets to 190 and chills there...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
NBrehm
Aug 5, 2015 07:57 PM
