Engine advice
Old Feb 11, 2010 | 02:54 PM
topher1316's Avatar
Engine advice
Hey guys, I was planning on taking out my 305 and do a plain jane rebuild, put it back in headers, mild cam. That is it, budget is kind of an issue in my case.
Now I have called a machine shop and described the engine. Pretty crappy from what they told me. I will more that likely need to get it line bored (they said $250). I am now debating on getting a bare block 350. Now with that I can bring most of the accessories intake. New heads, crank (crank is crap too), and cam.
What do you guys think. Remember money is an issue.
Old Feb 11, 2010 | 04:45 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: Engine advice
Get a 350.
Old Feb 11, 2010 | 04:54 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Engine advice
350
Old Feb 11, 2010 | 10:33 PM
topher1316's Avatar
Re: Engine advice
So I can buy a 350 block, and all I will need for it is heads, crank, and cam???
Old Feb 11, 2010 | 10:38 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Engine advice
may need fuel injector upgrade
Old Feb 11, 2010 | 11:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Engine advice
yeah build a 350, swap over everything else that you can. Since you are doing a mild build get a heads/cam package or just reuse the 305 heads and have them machined for a mild cam. ZZ4 or LT4 hotcam would be mild and cheap.
Can get a budget 350 rotating assembly for pretty cheap. Its worth it to have new rods/pistons/crank anyway.
Old Feb 12, 2010 | 08:30 AM
topher1316's Avatar
Re: Engine advice
Alright, well what can I swap over, and what do I need new??? Like do I need new rods, and or a new oil pan??
Old Feb 12, 2010 | 09:16 AM
goose88's Avatar
Car: 88 camaro
Engine: 383 stroker
Transmission: th350
Axle/Gears: stock rear end with moser 411s
Re: Engine advice
oil pan should be ok but that depends on what year model 350 block some have right handed dip sticks and some have left. early blocks have rightside. other than that you should be ok but, there is a posibility for bigger injectors but you will have to have the computer flashed
Old Feb 12, 2010 | 10:06 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Engine advice
you will need 24# injectors.. the 305 prom.. parameters are tame.. compared to the 350 a chip tune is a must
if you buy a 350 roller block all of the 305 parts will fit - pistons..
the the 305 heads will give you better compression.. but they have smaller valves and limit the flow.. not economical to machine!! will give a nice improvement [ unless you want series power] I would find a LT1 cam..
the rods are the same
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
