VSS?
Old Feb 23, 2010 | 05:39 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
VSS?
I have an 85 Z28, 305 non computer controlled, converting to a 350 TPI. What VSS will I need to use? I have a T5 tranny.
Old Feb 24, 2010 | 07:58 AM
S10Wildside's Avatar
Re: VSS?
What ECM are you going to use?
Old Feb 24, 2010 | 08:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: VSS?
I'm unfamiliar with TPI. That said, since you're using the OE cluster (where the VSS is located) and since your speedo is cable driven, why would you have to do anything?
JamesC
Old Feb 24, 2010 | 08:27 AM
Re: VSS?
Originally Posted by JamesC
Since the VSS is on the back of the cluster on your 85 and since your speedo is cable driven, I'd say you have to do nothing.
If you're going to use the 1227165 TPI ECM (86-89), then you'll use the 2,000 pulse per mile signal from the instrument cluster. Or, you can use Painless 60115.
If you're going to use the 1227730 TPI ECM (90-92), then you'll use the 2,000 pulse per mile signal from the instrument cluster to the ECM at pin C6 (you won't see this in the service manual schematics) and then change the calibration in the PROM to use an optical type sensor. Or, you can use Painless 60116 to pins A9 and A10.
Old Feb 24, 2010 | 08:46 AM
JamesC's Avatar
Re: VSS?
Thanks S10. Are you saying (hey, I'm a noob to the whole ECM and/or TPI business) that if the OP uses an ECM from an 86-89, he's essentially good to go?
Another question: There were, of course, TPI's in 85. Is the ECM different for that year?
JamesC
Old Feb 24, 2010 | 09:01 AM
Re: VSS?
OP??
Yes, the 1985 ECM is unique (and highly undesirable).
Old Feb 24, 2010 | 09:04 AM
JamesC's Avatar
Re: VSS?
OP?
Original poster.
JamesC
Old Feb 24, 2010 | 09:09 AM
Re: VSS?
Thanks S10. Are you saying (hey, I'm a noob to the whole ECM and/or TPI business) that if the original poster uses an ECM from an 86-89, he's essentially good to go?
As far as capabilities of the ECM, yes.
From a wiring standpoint, his car won't simply accept a TPI harness from any Camaro/Firebird. Not even a 1985 TPI harness. He will need a custom, stand alone type, engine harness or build/modify his own.
Old Feb 24, 2010 | 09:11 AM
JamesC's Avatar
Re: VSS?
Very informative, thank you--don't think I'll be swapping anytime soon .
JamesC
Old Feb 24, 2010 | 10:50 AM
TG Goose's Avatar
Engine: 355 SD TPI
Re: VSS?
Yeah i have to build my own harness, as i really only need a standalone system. I'll be using the 7730 ECM.
So I have a small vss box on the back of my speedo, your saying I can tap this to the ECM to get the signal?
Old Mar 3, 2010 | 09:58 AM
TG Goose's Avatar
Engine: 355 SD TPI
Re: VSS?
what is the exact wire from the 85 speedo VSS box that I need to splice into? I want to get all my ducks in a row so I get it right the first time. I'm about to break in a motor on a never tuned TPI engine.
Old Mar 27, 2010 | 11:59 PM
TG Goose's Avatar
Engine: 355 SD TPI
Re: VSS?
bump, still looking for an answer as to what wire i splice, and what I change in my .bin file to recognize the vss
Old Mar 28, 2010 | 01:27 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: VSS?
they have to be spliced into the vss wires to the ecm heres a link with the pinouts for the different ecms choose the one u will be using and locate the two wires. pm me if you need any more help
http://www.chevythunder.com/fuel%20i...5%20pinouts%20
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
