throttle body whistling
Old Apr 12, 2010 | 10:51 AM
devilish1's Avatar
Car: 88 T/A, 03 cobra
Car is 100% stock. Owned it for 2 yrs and TB has just started whistling right off idle. It's driving me nuts . Pitch changes as i crack it open more then goes away at about 25% throttle. I pulled intake tube and checked it, clean any build up on TB and blades. Whistle still there. Any ideas?
Old Apr 13, 2010 | 12:20 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: throttle body whistling
Hello devilish1!!
Wear at the throttle plate bushings causing a vaccum leak?????
Old Apr 13, 2010 | 01:16 AM
devilish1's Avatar
Thanks I'll give it a check. Any cheap fix?
Old Apr 14, 2010 | 12:31 AM
Hello devilish1!!
Only if you buy cheap bushings!!!
Old Apr 14, 2010 | 11:32 AM
devilish1's Avatar
So they do make a bushing kit for these? Any ideas where to find it?
Old Apr 15, 2010 | 12:31 AM
Hello devilish1!!
Was the throttle plate shaft bushings the problem??
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
