How do I0 gut the baffles from the air filter boxes??? and does it really work????
Car: 1986 Camaro Iroc Z28 (Corvette 5.7)
Engine: 1987 Corvette 5.7L TPI
Transmission: TR400
Axle/Gears: Stock
I been hearing all around about cutting out the bottom of the box where my K&N filters go but im not really sure what is it that you suppose to cut some help would really be appreciated thank you... (1986 Camaro TPI 350)
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: How do I0 gut the baffles from the air filter boxes??? and does it really work???
It's really easy. Remove the "Y" intake tube. Remove the K & N filters. Look down into the "boxes that house the 2 filters. There are 4 total air diverters (2 in each box). remove them. This alone will help the intake breath better, but not much. Once removed, use a Dremel drill and cut out the bottom of the boxes. You can also cut out the bottoms by using a "Saws All." But you will need to do a starter cut to insert the saw blade into the area that is to be cut. Make sure you use a Fine tooth blade. I say agian, Make sure you use a fine tooth blade. If you use a blade that has jagged large teeth, you will damage, crack, or even worst, break the whole filter base. So be carefull.
Transmission: TR400
Axle/Gears: Stock
Thank do you know if it really helps did you feel a difference when you did it on yours whats the increase on doing this sort of work?
Car: 1986 IROC
Engine: 355" TPI
It made a difference when I did it. Its not 10hp but its real.
Transmission: TR400
Axle/Gears: Stock
How did you do yours???
I went with the fine tooth saws all blade. The difference in performance is that I get a bit more of a jump from a dead stop. This is so because there is far less air intake restriction. The gains can be from 1 hp to 5 hp. It'll vary from car to car by means of altitude, summer vs. winter (cold air is denser and will give more hp) and engine mods.
Do you think a stock 87 350TPI with ceramic headers and 3" exhaust would benefit from this?
Car: 1989 Iroc-Z
Engine: 5.7L 350
Axle/Gears: Disc Posi
I just did mine using an air die grinder and a cut off wheel. It's a mop...it cant hurt. If your worried, do what I did. I went on the forums and asked who had a spear and bought it just in case. Easy to do. 15 mins
Transmission: TR400
Axle/Gears: Stock
Thanks Guy I just finished mine and it came out perfect just came back from a spin and you could deffinately feel a diference in the cars push when in take off..yea i think it would benefit even still with the headers cause all those baffles are doing in reality is lowering your air flow....once again thanks guys!!!!
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
wanted to say i removed those air dividers and wanna cut out the bottom like you guys have done but i dont have a dremel or any cutting tool, so how much does a dremel cost that will work ok for basic stuff? thanks.
If your just looking to buy one for basic stuff, I won't purchase a Dremel (brand name) as they can get pricey. I have a mastercraft 'dremel' kit and it works great. Cost me under $40 and has a bunch of attachments. Its one of those tools you randomly need and its good to have!
Car: 1989 Iroc-Z
Engine: 5.7L 350
You can also use a drill to put in a hole and then use a hacksaw blade to cut around. More time but also no cost if you have those tools. Prob easier to borrow them as they are more common.
Yup. Drill a hole and use a fine tooth blade along with a Saws All. If you have a friend who does carpentry, he'll have one or knows someone who does.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
