TPIS...
Old May 17, 2010 | 05:58 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
TPIS...
Are there any dyno numbers for thses combinations???
ASM 52mm Throttle Body,ASM Ported Penlum,ASM Large Tube Runners, TPIS Big Mouth Manifold on a 350?
These Items with TPIS ZZ409 Cam, 180cc Heads?
Old May 20, 2010 | 08:06 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Re: TPIS...
you need to be more specific on the heads. THere are TONS of 180cc heads that range from weak to amazing
Old May 22, 2010 | 02:00 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: TPIS...
regardless of the heads and cam without porting and a good tune it will have no *****. imo prob around 300
Old May 22, 2010 | 10:26 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: TPIS...
Old May 23, 2010 | 08:47 PM
Re: TPIS...
Airflow Research 180cc Street Competition Heads.
Old May 23, 2010 | 08:51 PM
Re: TPIS...
The People over at TPIS said this setup with their Level 5 retune, should net me
320-350HP with 430-450LBS. I was just wondering if some of the members here had a similar setup? Maybe they can provide me with some dyno sheets?
Old Dec 20, 2011 | 12:02 AM
Re: TPIS...
Anyone running a similar combo?
Old Dec 20, 2011 | 10:05 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: TPIS...
I had a zzz409 with age 195s and a ported too setup in my last iroc. I could never seem to get it to run right I recently switched over to an ls car and o my god absolutely love them. By far worth the swap or wait.
Old Dec 20, 2011 | 10:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TPIS...
TPIS is pretty spot on... 330-350whp depending on the dyno with that combination
Old Dec 20, 2011 | 11:05 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: TPIS...
TPIS gave you your answer, sounds like ?
Old Dec 20, 2011 | 01:20 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Re: TPIS...
My combo is VAGUELY similar:
Accel SR ported manifold, ported plenum, ASM runners, 52mm TB, Edelbrock 1 5/8 headers, 1.5 stamped rockers, Comp 302 cam, Dart IE SS 165/72 heads on my SB 357.
Made 304whp/431wtq on the chassis dyno. Their claim certainly sounds truthful.
Old Dec 20, 2011 | 01:35 PM
Re: TPIS...
That doesn't sound very encouraging...
Old Dec 20, 2011 | 02:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: TPIS...
If it wasnt done right with the install and tune, its going to be discouraging. It wasnt the combination of parts fault...they will work ok together.
Old Dec 20, 2011 | 03:17 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: TPIS...
here is one very very similar to that
http://www.eecis.udel.edu/~davis/z28/winter01/dyno/
Old Dec 20, 2011 | 04:56 PM
Re: TPIS...
Hey Orr89RocZ would you be so kind as to enlighten me as to what could of gone wrong with the Instalation?
The car hasn't been tuned on a dyno, but TPIS did supply the chip.
Old Dec 20, 2011 | 06:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: TPIS...
Mainly, cam was not degreed in properly...that could throw off timing events alot and cause subpar performance. Pushrod length could be too short or too long causing valve lift to be less than optimal. Guideplates positioned right for best geometry. Intake manifold port alignment...was the intake port matched to the head? No vacuum leaks, everything was sealed tight?
Little things like that could add up and make for a difficult running motor when trying to tune. Lastly, the tune is the biggest part. Dont expect to slap the parts together and drive away. Even a mail order chip designed for similar combos dont always work on similar combos I've tried my 383 tune on many similar 383-406 cubic inch builds on this board and have not had 1 person tell me it ran perfect for them...very similar heads/intakes/cams too!
Best to dyno/street tune once its running and all the mechanical checks have been performed. As long as the motor is not leaking or has any mechanical issues, the big gains in performance come from the tune.
Old Dec 20, 2011 | 07:55 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: TPIS...
correction i wrote all that on my phone i had the a zz409 cam and afr 195 heads . also had edelbrock base slp ported and siamesed runners, and ported plenum. with a 52mm throttle body up front
easySPEEDcamaro
May 5, 2007 10:49 PM
MrJ
May 8, 2001 08:19 AM
