Vacuum Ports on the throttle body? Help Please
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
As I am well on my way to almost finishing my TPI conversion I have a few questions. Where do the Vacuum ports on the Throttle body go to? throttle body is off a trans am with TPI
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Vacuum Ports on the throttle body? Help Please
There's only one vacuum port on the throttle body; it's on the bottom. This port is tee'd - one side goes to the vapor canister. The other side goes to the EGR solenoid.
The only other "vacuum" port is the large one on the passenger side for the PCV system.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Top one ;pass side, is supply air to pass side rocker cover for PCV system
Generally if running MAF system need this hooked up properly so airflow though PCV is metered by MAF .Running a open breather on one rocker cover and the PCV valve on other is same as un-metered vac leak
Car: 90 formula
Transmission: auto
i just did away with the egr. and blocked up the vacuum line. once and a while i get the code for it because i didnt get tuned yet but my egr was pretty much a vacuum leak
Car: 91 RS
Axle/Gears: 3.45
check out this thread i made about the same problem, it should be very helpful for you if you havent figured it out yet, along with some good pics from some of the guys that they posted up, and pics from me as well. hope this helps
https://www.thirdgen.org/forums/tpi/...-tpi-code.html
Car: 1990 Camaro RS
Axle/Gears: Posi
thank you that helped out alot, i dont have an evap canister on my car i got rid of it a while back. Do i need it? What does it do?
Car: 82 Z28
Transmission: T400
Car: 1990 Camaro RS
Axle/Gears: Posi
I have the fuel line vented out of the car, so I should be ok without the canister right.
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 16, 2015 05:45 PM
