which one to get?!?!
Old May 27, 2010 | 04:35 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
alright guys i wanna get better flow on my TPI before i do anymore upgrades.. i have a 91z28 350ci TPI with bbk underdrive pulleys, hooker shortys and bbk afpr..ive been searching and i dnt no wat to decide weather a HSR or a FIRST?!?!?! my future mods are a cam and heads and probly stoke it out to a 383ci and probly a procharger..so wat do u all recommend??!?!?! thanks in advance
Old May 27, 2010 | 06:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: which one to get?!?!
HSR is cheaper
Old May 27, 2010 | 06:01 PM
robg91z's Avatar
Engine: 350ci TPI
wat r the pros and cons of each manifold, also the prices?!?!
Old May 27, 2010 | 06:28 PM
robg91z's Avatar
Engine: 350ci TPI
wow i just checked jegs and summit and the Holley Stealth Ram intake is at $3,255!!!. did they higher the price on these or are they wrong?!?!
Old May 27, 2010 | 06:50 PM
grassyflats's Avatar
wow they are pricey...I am luckier than I thought!
question. is the egr eliminated with an hsr setup?
Old May 27, 2010 | 10:06 PM
Raging Sloth's Avatar
Car: 1987 iroc-z
Engine: 5.7 tpi
just for the intake its 325
http://www.summitracing.com/parts/WND-7540/
Old May 28, 2010 | 02:41 AM
robg91z's Avatar
Engine: 350ci TPI
Originally Posted by Raging Sloth
but thats a vortec setup..wouldnt i have to change my heads to vortec heads?!?!? or how does that work cuz im not really familiar with vortec and non vortec products idnt no wats the difference
Old May 28, 2010 | 03:02 AM
robg91z's Avatar
Engine: 350ci TPI
wat do u guys think about using the big mouth manifold and some SLP runners? would it be a good setup? and later adding a 52 or 58mm Throttle body?
Old May 28, 2010 | 02:54 PM
Car: 1987 iroc-z
Engine: 5.7 tpi
http://www.holley.com/7540.asp
retrofit for stock L98 tpi
Old May 28, 2010 | 04:57 PM
robg91z's Avatar
Engine: 350ci TPI
o well i guess ill get this one..its cheaper than the others and plus i still need to get the fuel rails
