Distributor install
Old May 28, 2010 | 07:59 AM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Distributor install
Fresh 355 TPI build. How do I initially install the distributor? I dont have a mark for where the rotor was previously. Do i just install it with the rotor pointing to the #1 cylinder? motor is at TDC
Old May 28, 2010 | 10:34 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Distributor install
Point the rotor at the number one tower on the cap, you may need to turn the oil pump shaft if it is not lined up right.
Also remember that the rotor will turn a few degrees clockwise when the gears engage so put it in alittle behind where you want it to end up.
Old May 28, 2010 | 03:47 PM
TG Goose's Avatar
Engine: 355 SD TPI
Which tower on the cap is #1? This isnt for an HEI distributor, its for a Computer Controlled remote coil 85-92 TPI dist.
Old May 28, 2010 | 04:16 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Doesn't matter. Any tower can be #1 provided you have the harmonic balancer at 0 deg and the rotor pointed at that tower. Then just put the wires on in the proper firing order, (1-8-4-3-6-5-7-2). The traditional spot is about 4 o'clock for #1 when looking down at the dizzy.
Old May 28, 2010 | 05:01 PM
TG Goose's Avatar
Engine: 355 SD TPI
well with that answer, it still doesnt tell me where to point the rotor.
Old May 28, 2010 | 09:18 PM
watajob's Avatar
Car: 92 T/A 'vert
Jesus H. Christ
Old May 28, 2010 | 11:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pick which terminal on the cap you want to be # 1 plug and point the rotor there.
Then put wires on in correct order as stated.
motor is at TDC
But is it on the compression stroke?
Piston comes to top twice per combustion cycle ( crank goes around twice / dist turns once ) so you may end up with rotor 180 degrees out if you line up rotor with # 1 if at TDC on exhaust stroke
Old May 29, 2010 | 02:07 AM
watajob's Avatar
Car: 92 T/A 'vert
Good point.
Old May 29, 2010 | 06:30 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Diagrams showing firing order will also show where the #1 tower on the distributor should be. http://www.google.com/#hl=en&source=...28cd8acda262ff
Here's one diagram from the link above. http://www.joby.se/corvette/misc/firing_order.gif
As was said it has to be installed in that position only when the #1 cylinder is at TDC of it's compression stroke.
If you haven't pulled the dizzy, or if you have reinstall it, but be sure it's completely seated, if it's not then it's not aligned with the oil pump. Once it's completely seated do the following:
  1. This step positions the rotor while keeping the oil pump engaged; Loosen hold down and turn the distributor until the cap is positioned as in the diagram, tighten hold down and remove cap if the rotor isn't pointing at the #1 tower of the distributor cap as shown in the diagrams turn the engine manually clockwise until it is.
  2. install the cap and tighten screws. Scribe, or paint a mark on the base of the distributor and onto the intake manifold.
  3. Remove the distributor.
  4. Remove #1 spark plug and plug the hole with a rubber stopper.
  5. Turn the engine manually clockwise until the stopper is forced out by compression.
  6. The timing mark on the dampener should now be to the left (passenger side) of the timing tab, continue manually turning the engine until the mark is aligned with the zero mark on the timing tab, the engine is now at TDC of #1 cylinder's compression stroke.
  7. Reinstall spark plug & wire.
  8. Install the distributor and align it to the marks you made.
  9. Install the lock down and leave the bolt finger tight and connect all wiring.
  10. Disconnect the "Set Timing Connector."
  11. Start engine and set the timing.
  12. Tighten hold down and recheck timing.
  13. Turn off engine and reconnect "Set Timing Connector."
Hope I didn't miss anything.
Old May 30, 2010 | 06:45 PM
TG Goose's Avatar
Engine: 355 SD TPI
Ok, so I think this makes sense:
As long as I am set on the compression stroke of TDC, it doesnt matter where the rotor points to, because now what ever tower it is pointing to, is #1.
I wanted to have the distributor wiring harnesses facing a certain direction for cleaning up the wires and to make it easy to swap out, wire in an MSD box, set timing etc.
Old May 30, 2010 | 09:33 PM
watajob's Avatar
Car: 92 T/A 'vert
Correct!
Old May 31, 2010 | 01:39 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I wish someone had applied the vortec distributor cap design for the HEI sure would make routing wires easier and look good too.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
