Code 33 any ideas ?
Old Jun 17, 2010 | 12:53 PM
timonator's Avatar
Code 33 any ideas ?
I have codes 32and33 on my car(91 z28 5.7 tpi). Iknow that the 32 is because I don't have my egr connected right now. I can't figure out why I have a code 33 though. All of my vaccuum lines are connected. The only thing that seems questionable to me is that the PCV valve doesntvseem to seal tightly in the valve cover grommet. Any ideas ?
Old Jun 17, 2010 | 01:09 PM
tpi81's Avatar
Car: 85 Camaro-81 Chevy
Engine: 350-350tpi thats right tpi n my trk
Transmission: none-700R4 for gas
Re: Code 33 any ideas ?
Code 33 is MAP Sensor Voltage (HIGH) try new MAP sensor around 50 to 55 bucks!!!
Old Jun 17, 2010 | 01:55 PM
timonator's Avatar
I've already changed the MAP sensor.
Old Jun 17, 2010 | 03:28 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Clear the codes then disconnect and plug the vacuum line from the map sensor start the car and see if the code comes back (the ecm will use a preset value for the map sensor)
It may be a vac leak.
Old Jun 17, 2010 | 04:54 PM
timonator's Avatar
Ok, I'll try that. The ses light only comes on at cruising speed though. And I don't think I can drive around with the MAP disconnected, can I ?
1992Vortec
Aug 31, 2015 08:05 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
