fuel pump circuit issues
Old Jun 23, 2010 | 02:32 AM
1987-iroc-z383's Avatar
Car: 1987 chevrolet camaro Iroc-z
Engine: 383 tpi
Transmission: built 700r4
Axle/Gears: posi 3:45
I am having a no prime for 2 seconds issue upon ignition on. The pump is fairly new, new fuel pump relay, no codes. I believe it started when I took power from the relay for my 3 wire heated O2 sensor, but not positive. Car will run obviously from back-up oil pressure switch/ecm. I have grounded the aldl g terminal and no pump power, I jumped it at the relay and the pump worked. I did a little diagnosing using a tpi book i have, and it suggested i had an open somewhere in the relay circuit... could this possibly be from the heated O2 sensor install? If the car has oil pressure and Ive just shut it off and go to start it up again, the pump will prime... any suggestions?? Another quick question, what fuel pressure should I start with on my modded 383?
Old Jun 23, 2010 | 03:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump circuit issues
That would suggest the relay is faulty because power at ALDL terminal goes through the normally closed contacts ( power off ) at relay to pump. Having the pump run by jumping the relay terminals shows the wiring to pump is good.
Can you make relay work by putting 12V on the green / white relay control wire ?
Old Jun 23, 2010 | 03:12 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I believe it started when I took power from the relay for my 3 wire heated O2 sensor, but not positive.. could this possibly be from the heated O2 sensor install?
What terminal on the relay did you use for O2 power?
Old Jun 23, 2010 | 07:05 PM
Engine: 383 tpi
I used the dark green/white which had the 2 second 12 volt pulse after ignition... I have since removed the heated o2 wire from the circuit and the pump functions fine now. Was it the wrong wire? Should I connect my O2 to the big tan/white wire? I took power from 465. Should I take from red 120? Even though I dont have red...:S
Old Jun 23, 2010 | 07:51 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I used the dark green/white Was it the wrong wire?
Sure was.
Should use the E terminal on relay ( regardless of color) which is the wire going to the pump.
That way you are using power that is switched by the relay ; not the power to turn on the relay
Should be two thicker wires at relay.On goes to batt and has full time power.The other is live when relay on; that is the one you want
Old Jun 23, 2010 | 08:27 PM
Engine: 383 tpi
I just wired it to ignition. However now that the fuel pump circuit is working properly, I'm having a crank but no start... it will eventually start. Maybe my timing is off now? I just installed a holley afpr and it may be leaking through the adjuster ****... rediculous.
Old Jun 24, 2010 | 01:23 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I'm having a crank but no start... it will eventually start. .
Is the relay coming on for 2 seconds when you turn the key on?
If not you will have no fuel pressure at rails and are waiting for the oil pressure switch to run the pump when engine cranks
Old Jun 24, 2010 | 02:02 AM
Engine: 383 tpi
Yep the pump primes like it should... the new holley afpr may be leaking from the adjuster ****... not cool.
Old Apr 29, 2011 | 05:16 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Originally Posted by vetteoz
Sure was.
Just was looking where to tie in my heated O2. I see you are saying to tie into terminal E, in my case terminal E is orange and always has power(12.64v). If I tie into that the heated O2 will always be on, dont I want a power source that is only on when key is forward and running?
A- Tan/white tracer
B- Black/white tracer
C-Green/white tracer
D- Red
E- Orange
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
