87 z28 cranks but cuts right back off
Old Jul 19, 2010 | 09:27 PM
jsteadman's Avatar
ive got a 87 z28 350 tpi got new fuel pump made sure its getting gas to the rails all the spark plugs look pretty good and its getting fire as long as you hold the key good compression all vacumes seem to be good but it cuts right back off every time i get it to crank any suggestions
Old Jul 19, 2010 | 09:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 87 z28 cranks but cuts right back off
Checked fuel pressure at rails with gauge?
Old Jul 19, 2010 | 09:42 PM
jsteadman's Avatar
yeah its got about 20 pounds
Old Jul 20, 2010 | 03:57 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
TPI needs 40psi fuel pressure when cranking.
Old Jul 20, 2010 | 09:58 PM
jsteadman's Avatar
cleaned out fuel rails and fuel lines and gas tank got it up to 40 psi but still have same problem i messed with the distributer a little bit and got it to stay crunk for about 10 seconds but still cuts back off tried to give a little gas before it cuts off but it doesnt make a difference
Old Jul 22, 2010 | 09:33 PM
jsteadman's Avatar
finally got it running had a wire crossed
Old Jul 22, 2010 | 09:37 PM
jsteadman's Avatar
1986 140 mph speedometer in 1987 z28 with 85 mph?
does anyone know if a 140 mph speedometer out of a 1986 camero will fit and hook up and work right in 1987 z28 with a 85 mph speedometer? if so please let me know thanks
Old Jul 23, 2010 | 03:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: 1986 140 mph speedometer in 1987 z28 with 85 mph?
The speedos are both mechanical and should be interchangable.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Caspar
Jun 19, 2016 11:19 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
