Which spark plugs should I get???
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok so my car is a 92 z28. It has a vortec 350 in it from 96. Has the vortec intake, ported plenum and ported slp runners. I am gonna replace the plugs and wires and wanted to know what would be best for this car performance wise.
Part numbers if you have them please.
Axle/Gears: G92
Re: Which spark plugs should I get???
Also what timing would be good with this?
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
dont wanna sound stupid here but e3 spark plugs ...horsepower tv has me sold on them bigtime
its all about complete fuel burn
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
ive used NGK spark plugs with no problems and its been 4 years that i have them..
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
i'm running NGK plugs, love them. I'm running Edelbrock aluminum heads, plug is an NGK - BKR8EIX or 2668 depending on where you purchase them.
Axle/Gears: G92
I'll just get stock plugs and upgraded wires, should I get the ones that came stock with the 96 vortec or the 92 l98 ones? Is there a difference?
Axle/Gears: G92
Also should I just use a replacement stock rotor and cap?
Axle/Gears: G92
Car: 87 GTA
Engine: tpi 350
a quality cap and rotor with brass terminals from the auto parts store is perfect.
start with timing set at 6 adjust from there. each motor/conditions are different. your combination may like a littl emore advance. set it, test drive it and see what feels best. if you have a scanner you will be able to SEE the differences.
Car: 87 GTA
Engine: tpi 350
i think cr43ts plugs work well. good all-around plugs. by the way the "c" stands for commercial grade and are much better than just r43ts plugs. compare them and you will see.
My timing is set at 10 on the distributor but it's at 6 in the ECM... it runs good though but should i re-tune the chip to match it? (86 tpi 165 ecm, cammed, heads+intake ported, bored 0.030, etc)
Axle/Gears: G92
I went with all accel stuff, I'll let you know how they do
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
