Throwing codes after AC delete
Old Aug 11, 2010 | 11:09 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
So I went ahead and did the ac delete today on my car. After I was done decided to take her for a spin tried giving her gas and she died. Checked codes and it's throwing a 12,33, and 42. Need help on fixing these. Thanks.
Old Aug 11, 2010 | 11:27 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Throwing codes after AC delete
12 is not a code, its the starting code pretty much.
33 is for High volt/low vac for map/maf
42 is Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
Those have nothing to do with the AC delete, sounds like you might of left some things unplugged or not put them back on properly.
Old Aug 11, 2010 | 11:30 PM
3rdgenred's Avatar
But I put everything back correctly though. All I left unplugged was ac stuff ithoughtthat when I threw codes it'd be for ac stuff not this I don't know what else I need to plug it. I plugged the Maf back in that's all I needed to do.
Old Aug 12, 2010 | 12:04 AM
Carlos773's Avatar
Clear the codes, take off the negative from the bat and see if the codes come back, if they do, look into them.
Old Aug 12, 2010 | 12:22 AM
3rdgenred's Avatar
I tried that. I went ahead and disconnected the negative battery feed and then unplugged and replugged the est wire, still idling like ****. Im really lost and kinda upset now and I wish that this didnt happen to me. Any one have knowledge about est and how to set my timing. I think that it has to do something with the timing because listening to the exhaust while the cars running, you can hear that the exhaust isnt smooth as possible. Im just scared that ill never get this thing running again.
Old Aug 12, 2010 | 01:41 AM
Carlos773's Avatar
Well it gives a code for the Map/Maf, Start there and see if that fixes your idle problem. Look around the forum about code 42, Its asked alot and probably has the steps for you to look into.
Be glad you sorta know what you have to deal with.
Old Aug 12, 2010 | 01:55 AM
3rdgenred's Avatar
I know that its somewhere to start but i guess this will give me time to start cleaning up the engine bay alittle too as well.
Old Aug 12, 2010 | 02:01 AM
3rdgenred's Avatar
Ohh and its only throwing code 42 now after the reset.
Old Aug 13, 2010 | 05:04 PM
3rdgenred's Avatar
okay so im lost and don't know where to begin with this code 42. bump for help.
Old Aug 14, 2010 | 12:11 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Have you checked that the connector that is disconnected to check timing is connected? That's right around where you were working and if may have inadvertently gotten disconnected/broken/etc. IIRC, that'll throw a code 42. Our cars are getting old now and there also may be an age related problem with that wire, (broken, chafed through, corroded connector, etc.).
Old Aug 14, 2010 | 12:16 AM
3rdgenred's Avatar
That could be it. I was moving it around slot when I was doing the swap. I just don't know how to check it but I'll look into it.
Old Aug 14, 2010 | 02:40 AM
watajob's Avatar
Car: 92 T/A 'vert
It's the only connector that sticks out of the bundle of wires that are right above the heater box.
Old Aug 14, 2010 | 02:43 AM
3rdgenred's Avatar
No i know what it is but how to check it is where im lost. Ima get a timing gun and make sure the timing is good. If not then ill look into the cap, rotor, and the ignition module next.
Old Aug 14, 2010 | 03:15 AM
watajob's Avatar
Car: 92 T/A 'vert
First would be an ohm meter to make sure it's not broken or grounded.
Old Aug 14, 2010 | 07:24 PM
3rdgenred's Avatar
So i have a ohm volt meter. Im no good with electrical stuff so i have no idea how to test a wire for voltage. How could i do that.
Old Aug 31, 2010 | 06:41 PM
3rdgenred's Avatar
So after nearly 2 weeks of it sitting infront of my house I finally got enough strength to go ahead and fix my car. The ignition module went bad somehow. When I was running the codes and testing my car i was noticing that it was actually putting the car in the mode to set the est as if the est wire want plugged in. I went ahead and checked all leads and no frays, cracks, or bends so it wasn't that. Then i traced it to the ecm and was noticing a .5 volt on the est wire in the ecm. Went ahead and swapped that out and it was still throwing the damn code. My last option was the ignition module. Luckily enough for me, I was able to get the money back for the ecm because the one i had wasn't broken, and i saved 190 bucks on that. After i put the new ignition module in, reset the timing (adv. it 2*) she runs fine now. Couldn't be happier rite now.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
