305 tbi to 350 tpi help
Old Dec 4, 2010 | 06:34 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i have a 1992 rs with 305 and im pullin out a 350 tpi out of a 88 iroc i took the entire harness out what do i need off it for the tpi im getting rid of the ac and mb the smog stuff not sure yet also are the fuel lines in my tbi good for the tpi im know im going to have upgrade the fuel pump i really appreciate the help also how much boost can the stock maf sensor read im try reach 400 rwhp with a turbo
Old Dec 6, 2010 | 03:18 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 305 tbi to 350 tpi help
The bulkhead connector and instrument panel connector on the 88 harness will need to be repinned, they will not match up with the 92 connectors. Another option would be to repin the existing tbi harness to work with the tpi.
You will also need to get atpi throttle cable and a tpi kickdown cable as the tbi ones are too short.
Old Dec 6, 2010 | 03:25 PM
Transmission: auto
the bulk head connecter your referring to is the next to the brake booster that needs to be repined?
Also do know were i could get a diagram for it. were are the interment panel conector located on the harness are they both by the brake booster
Old Dec 6, 2010 | 03:26 PM
Transmission: auto
i have all the cables from the 88
Old Dec 6, 2010 | 04:42 PM
Yes it is the one next to the brake booster.
The instrument panel harness is the short harness that comes off where the plugs are for the ecm, that is connector c207
I've posted 2 pin diagrams, the 89 c100 and the 92 c100 you will need to rearrange the wires on the 88 harness to match the 92 connector, there are 2 plugs in the c100 conn, you only need to concern yourself with the larger one, no's 4 and up, the smaller is the headlight harness, you don't need to change that as the original stays on the car.
Hope this helps
Attached Thumbnails 305 tbi to 350 tpi help-connector_1989a_c100.jpg   305 tbi to 350 tpi help-connector_1992a_c100.jpg
Old Dec 6, 2010 | 04:45 PM
I can only post 3 pics at a time so here are the pins for the c207 conn
Attached Thumbnails 305 tbi to 350 tpi help-connector_1989a_c207.jpg   305 tbi to 350 tpi help-connector_1992a_c207.jpg
Old Dec 6, 2010 | 06:12 PM
Transmission: auto
quick question why do i have to re pin the plug for the ecm i have the 88 ecm too and the entire harness for it like the part that goes through side of the car from the ecm i understand the part by the brake booster needs to be done i don't understand the the ecm part srry if im coming off receptive
also i saw your car use to be tbi which would you recommend is easier to do if was to moody my tbi harness what would need to be done thanks i really appreciate it
Old Dec 6, 2010 | 09:27 PM
Yes I did the same swap 15 years ago, I don't even own that car any more, but I used all 89 parts so I would not have to repin anything. I did it because the tbi motor needed a ring job, and buying a rebuilt motor was cheaper and I was able to upgrade, It took me some time to get everything right, but once i did it was a beast.
The little short harness is for the instrument panel, gages and lights ect, it doesn't plug into the ecm, it connects to the main harness under the dashboard.
one more thing, you'll need to upgrade your exhaust, the 2-1/4" pipe is a little too restrictive. I blew the exhaust gaskets right out of it within a week.
Old Dec 7, 2010 | 06:12 PM
Transmission: auto
well i got entire exhaust off the roc its got a big exhaust pipe so yea im also turbo my tpi
so i will need to tune my car did you tune it yourself ? if you did what did you use im wanna have everything need to make this swap a quick as possible not a 3 month headache
Old Dec 8, 2010 | 05:32 AM
In my firebird I used a stock chip from an 89 gta, I dabbled in chip burning a little but only on my 86, I found that car ran alot better using 89 software as well.
Old Dec 9, 2010 | 09:17 PM
Transmission: auto
another question can use the stock tbi fuel line for the tpi or do i need the tip fuel lines too
Old Dec 10, 2010 | 05:07 AM
the hard lines are okay, but you will need to get the tpi flex lines that go to the fuel rail
Old Jan 6, 2012 | 03:24 PM
ts180389's Avatar
Car: 1991 camaro rs
Engine: 350 tpi
please give me a call doing the same thing need help 678-877-0168 chad
1991 camaro rs 305tbi to 1989 350tpi swap
Old Oct 8, 2015 | 04:44 PM
Erick James's Avatar
Im swapping a 1988 camaro 305tbi to a 1987 formula 350tpi. Bought engine bay harness & pcm for tpi. Bought larger volume fuel pump to support injectors. Will serpentine belt system swap from 88' camaro to the 87'formula motor?
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
