383 TPI , how much hp?
Old 12-06-2010, 02:06 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
I am planning to this by spring. http://www.100share.com/Need-The-Perfect-Engine-W.htm Buy this 383 with ported slp runners , phelum, intake. intake will be stock and just ported and match. it will have 24 lbs injectors. and tuned. I will be replace my 305 tpi. I will rebuild my 5 speed tranny with this combo and diff.
The Big question is... will this engine bolt right in my engine bay and will my intake bolt on? Will my tranny bolt on? I just want to make sure before I place the order.
Thanks for your help.
Old 12-06-2010, 02:25 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: 383 TPI , how hp?
The engine should be an easy bolt-in piece.
The intake depends on the bolt pattern of the center two bolts of the heads. As far as I know they changed in 87.
The transmission bellhousing is the same as both blocks are Gen I Chevy SBCs so your current tranny should bolt on without any problem.
Old 12-06-2010, 02:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If that is all you want to know...yeah, you're good but there will be other issues.
Old 12-06-2010, 09:06 PM
pestrada38's Avatar
Like what issues? please be very detailed. and how much HP can I get with this combo and adding dyno don headers with a gmmg exhaust?
Old 12-06-2010, 09:23 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're totally choking the engine with a stock TPI intake, even if its ported. 24lbs injectors will probably not be enough fuel either. And you'll probably break the T5 transmission if you do any kind of racing.
To work best with a 383, you need short runners such as a TPIS MiniRam or Holley Stealth Ram.
Old 12-06-2010, 10:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
The specs on that engine are designed for diesel truck like performance which is fitting with stock TPI. .427" lift cam...not any greater than stock L98 cam. NO idea what the duration is that they use but i'm sure its a RV type 195 to 208 deg duration cam.
heads are very mild not any better than stock either.
So with that said, I think it will fit well with ported stock base, SLP runner combo. 0-4500 rpm range max. Peak in the 3800-4000 rpm range likely. Extreme torque stump puller. Not much hp/probably not much faster than a bolt on L98 with short runner intake
Old 12-07-2010, 08:53 AM
89chevysb's Avatar
Car: 89 Camaro RS
Engine: 305 soon to be 383
Transmission: 700r4/T56
Axle/Gears: 3.27 ratio
Re: 383 TPI , how much hp?
Make sure to upgrade the transmition to something more powerful, make sure you have six inches between the alternator and the rest of the engine bay. One thing you MUST do is to change your intake you are going to NEED a new performance intake if you plan on doing the swap. Also if you are going to ad that power if your car is older make sure the rear axle is still in quality condition, check for rust or holes (I had that porblem when i swaped a v6 for a supercharged 350 the power was two much on the rear axle and it dropped because of one rust spot.
Old 12-08-2010, 11:47 PM
pestrada38's Avatar
the corvette forum recommended this engine. alot of them are using 383 with tpi. look i not to racing all the time. just want someting with more hp and for daily cuise. more for show. some where between 330-380hp
Old 12-09-2010, 05:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
For what ; tractor pulling?
Smeding's even state it is a engine for towing and 4 x 4 trucks
TPI on that engine will probably make more torque but less Hp than advertised in the link
Old 12-09-2010, 08:05 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Why is this?
Youll find on forums, in the auto parts store etc many giving advice who have never built anything in their life be careful who you listen to. Reading only gets you so far
Old 12-09-2010, 10:23 AM
Former Sponsor
InjectorsPlus's Avatar
Tow truck engines seem to be popular....
And yes, 24 lb injectors are too small for that engine if it's going to make any kind of power. They need to be closer to 30 or more.
Old 12-09-2010, 10:40 AM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
From the sounds of it, it doesnt seem like it's going to be making much more than a stock 350, I would think 24 lbs would be good.. Worked fine for my 350 tpi that made more power than that, just have an afpr
Old 12-09-2010, 10:44 AM
Former Sponsor
I guess, anything over 325HP I would go bigger than 24, and I think he should be over that....
Old 12-09-2010, 11:04 AM
iroc-z_23's Avatar
Engine: 355 SBC
If it is actually 345 peak at 4,500 like it shows than yeah it would probably be worth it for bigger injectors, either way I think that the tpi is a great set up for this motor
Old 12-09-2010, 01:34 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Where did you get this info from? Bad info to me.
Old 12-09-2010, 02:08 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Well the tranny part he gets from the t-5 not being strong enough. Factory cars did not come with a 350 5 speed because the t-5 was not strong enough to back it, not to mention a 383..
Old 12-09-2010, 03:25 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I was under the impression 24lb injectors would support 350whp at 80% cycle duty...based on 1989GTATransAm's results
That 383 will not be ANYWHERE near 350whp so 24's should be enough.
Old 12-09-2010, 03:41 PM
Former Sponsor
350 WHP is what? give or take 400-425 at the crank...I'd like to see bigger. That's just me.
I don't see why someone would use a 4 bolt main and build a 383 that isn't more than 400HP...
Old 12-09-2010, 03:42 PM
Former Sponsor
Geeze, that is a truck motor.
toronto formula
11-10-2015 06:17 AM
bdads
08-24-2015 06:01 PM
86White_T/A305
08-17-2015 12:16 AM
85Iroc-Z
08-13-2015 01:58 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 383 TPI , how much hp?
