Need help! Seems to be running rich
Old Dec 16, 2010 | 08:41 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
I'm trying to fix up my 5 speed camaro good enough for the guy that's buying it to drive it home with no problems. It runs very rich and you can smell the gas. The only thing I can think of is the adjustable fuel pressure regulator being set too high maybe. What is the fuel pressure supposed to be set at for stock 305? Any suggestions on what this might be? I've fixed all the vacuum leaks under plenum and I've replaced cap, rodor, plugs, wires, different throttle bodies, new fuel filter..
Input would be much appreciated
Old Dec 16, 2010 | 09:02 PM
el raptor's Avatar
Car: 89 GTA
Engine: 350 L98
Transmission: auto
Re: Need help! Seems to be running rich
bad o2 sensors can make it run rich
Old Dec 16, 2010 | 09:27 PM
iroc-z_23's Avatar
Engine: 355 SBC
It cuts in and out though making it run really rough and then it will snap out of it for a second then start running rough.. Are you sure it's nothing with the fuel injection? Vacuum leak? Exhaust leak?
Old Dec 16, 2010 | 09:48 PM
el raptor's Avatar
Car: 89 GTA
Engine: 350 L98
Transmission: auto
not sure, but they are cheap and easy to replace. good starting point and you already replaced alot of other stuff. had a 92 lumina z34 that ran real rich, blowing black smoke and stained the rear bumper. it did idle rough also. the friend i got it from replaced all kinds of stuff too. i put in the sensor and it ran fine. so simple
Old Dec 16, 2010 | 10:25 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
42- 43.5 lbs for the fuel pressure. And I also would change the O2 sensor.
Old Dec 16, 2010 | 10:50 PM
iroc-z_23's Avatar
Engine: 355 SBC
thanks for the input its the first thing im going to check!
Old Dec 16, 2010 | 10:59 PM
iroc-z_23's Avatar
Engine: 355 SBC
thanks i will also check that. will lowering fuel pressure lean it out or does fuel pressure have that effect? Also is this 42-43.5 WOT? and also im kind of unfimiliar with the term "closed" and "open" loop ? whats it referring to with fuel pressure?
Old Dec 16, 2010 | 11:48 PM
red rock's Avatar
Car: 1987 iroc
[QUOTE=iroc-z_23;4762899]thanks i will also check that. will lowering fuel pressure lean it out or does fuel pressure have that effect? Also is this 42-43.5 WOT? and also im kind of unfimiliar with the term "closed" and "open" loop ? whats it referring to with fuel pressure? Closed loop, is when the engine is first started (cold) the ecm doesn't recognize the O2 sensor to regulate fuel, it just works on a preprogram. Open loop is after the engine warms, the ecm opens up the O2 and other sensors to regulate the fuel. Checking the fuel pressure should be done at idle with the vacuum line disconnected from the regulator and the vacuum line plugged.https://www.thirdgen.org/open-loop-closed-loop
Old Dec 17, 2010 | 12:29 AM
iroc-z_23's Avatar
Engine: 355 SBC
[QUOTE=red rock;4762938]
Thanks a bunch I think I'm on the right track here!
Old Dec 17, 2010 | 01:59 PM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
It is open loop at start-up and goes to closed loop when o2 sensor gets heated up.
Having the fuel pressure too high could definitely cause it to be running rich.
Old Dec 17, 2010 | 04:53 PM
red rock's Avatar
Car: 1987 iroc
Yea i guess i had open& closed backwards, sorry for the wrong info., it was late, she had her clothes off and i spilled by beer?
Old Jan 30, 2011 | 12:02 AM
iroc-z_23's Avatar
Engine: 355 SBC
turned out NOT to be o2 sensor, but a hair line crack in the o-ring of the fuel pressure regulator. i took upper plenum off and dumped gas out.
let that be a note that if your running really rich, always check your afpr vacuume first.
Old Jan 30, 2011 | 01:31 AM
red rock's Avatar
Car: 1987 iroc
Good catch, how did you find that it was a bad o-ring. Did you completely take the FPR apart and notice a cracked o-ring?
Old Jan 30, 2011 | 05:47 AM
iroc-z_23's Avatar
Engine: 355 SBC
Well when I disconnected the vacuum line to the afpr it was spewing gas into my plenum so that right there told me theres something wrong right there and once I got to taking the plenum off to get to the afpr and took it off I couldn't even see the tear just looking at it, had to stretch the o-ring to see it. I can't believe that was the problem after spending 100s in other things that were fine, but luckily it was an easy fix and the guy was pretty happy with the car
Old Jan 30, 2011 | 05:49 AM
iroc-z_23's Avatar
Engine: 355 SBC
But it has a new o2 sensor anyways lol
Old Jan 30, 2011 | 08:13 AM
InjectorsPlus's Avatar
Former Sponsor
Never mind, I should learn.....read the WHOLE thread.
Old Jan 30, 2011 | 08:51 AM
iroc-z_23's Avatar
Engine: 355 SBC
Never would of thought a temp sensor would make it do that, but yes found the problem thanks though
Old Jan 30, 2011 | 09:44 AM
Former Sponsor
Frequently over looked...
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
