Help Switching fom roller block to flat tappet
Old Dec 24, 2010 | 11:06 PM
IROC_Champion's Avatar
Car: 1991 z28 Convertable
Engine: Tpi 350
Axle/Gears: 273 built ten bolt posi
ok i have a 91 z28 just wonderin if the factory cam from the original 305 tpi was only specified to work with the map setup,also im putting in 89 k5 5.7 which i know is not a roller engine would this motor work fine with the map sensor also i have a stage two chip dont know if that helps any advice
Old Dec 25, 2010 | 01:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help Switching fom roller block to flat tappet
Computer doesn't know what engine is underneath the intake
All you need is the correct stock 350 chip for the computer and a knock sensor to suit a 350 MAP engine
( 305 KS is different )
Old Dec 25, 2010 | 12:08 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You wanna stay factory roller block. With the non roller block you would have to buy a flat tappet cam, push rods and lifters. Or buy a roller cam made for that block and lifters which cost more money.
Old Dec 25, 2010 | 05:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
From his original post it appears he has a complete 5.7 flat tappet engine; not that he want to swap his roller cam for one in his 305?
Old Jan 11, 2011 | 06:24 PM
Engine: Tpi 350
yea its a complete engine im just transferring the pulleys and sensors cam has lower duration though will i have any problems wit that since the map setup works off vacumn?
beastin91rs
Oct 9, 2015 07:38 AM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
Dialed_In
Aug 20, 2015 01:45 PM
anesthes
Aug 8, 2015 09:37 PM
