TPI idle problems New heads cam intake
Old Dec 30, 2010 | 04:29 PM
travis_henry's Avatar
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
I have a 89 Iroc l98 motor and i just bought edelbrock performer heads 2.02 int 1.60 exhedelbrock TPI high flow intake scorpion 1.6 roller rockers comp cam .495 int lift .502 exh lift 110 lobe sep, all roller cam. i got new injectors and everything. hydro cam by the way. Ok the motor runs awsome while holding the throttle open a little but it wont idle for crap. all the sensors are plugged in and new tps and idle air. i drove it around the block and it has crazy power but it wont idle for crap. Im at aloss any help please
Old Dec 30, 2010 | 05:33 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: TPI idle problems New heads cam intake
check for vaccuum leaks
check the voltage at the new tps, should be 0.54 volts closed and should increase to 4.0 volts as you open the throttle.
Old Dec 31, 2010 | 10:48 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
ok thanks for the info. so just curious is the cam i put in it to big for the computer?
Old Dec 31, 2010 | 11:12 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
TUNE.
Old Jan 2, 2011 | 10:44 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
White'89 is right. You have to tune the ECM according to the new engine specifications.
Old Jan 2, 2011 | 10:04 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
thanks for the reply but i got it tuned yesterday.
Old Jan 3, 2011 | 04:34 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Any Trouble codes or "check engine "light?
Is the IAS Motor working (yes, I realize it is "new"), that does not mean it is working? TPS voltage should be .54 V closed and around 5V @ WOT. Did you set your minimum idle speed?
Check the manifold vacuum, if your manifold vacuum is low (under 12-14") at idle, your ECM will not be able to compensate.
You also have replaced the injectors, did you go stock size or larger? Large injectors and low vacuum will cause all kinds of problems.
Is your fuel pressure set to stock levels or higher than stock?
Are you running the stock MAF System or a later Speed Density system?
Is the camshaft a "computer" type cam? Or something else. That is a lot of cam for a stock ECU to deal with. Don't get me wrong, that is not a HUGE cam, but it takes very little in the cam department before it starts causing problems.
Old Jan 6, 2011 | 06:24 PM
badmoon47's Avatar
The 110 LSA on your new cam probably has alot more overlap than stock which causes low idle vacuum. The low idle vacuum causes the ECM to think you are under a load at idle and is probably dumping fuel into your engine thus bogging it down at idle. If you have access to a laptop with datalogging capability, you should be able to see the problem fairly quickly.
Old Jan 6, 2011 | 08:11 PM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
I almost have the same thing. Not to hijack but im interested to see what the solution is. My cam is a little different its a little lower on the lift but almost the same specs. The vacuum is low about 12". The only question I have is how do you tune the ecm but its best left to a different forum all together.
Old Jan 6, 2011 | 08:39 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
weelllll how does it run
Old Jan 7, 2011 | 07:35 AM
badmoon47's Avatar
At 12" at idle you are probably running VERY rich with a stock tune. You can either take it somewhere to have it tuned or learn to do it yourself. My engine pulls 14" at idle and had the same problems. I gave up having other people tune it "over the phone" and started burning chips myself. Got everything I needed from MoatesEFI for around $100. Turned out to be a great investment.
Old Jan 7, 2011 | 08:35 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
what kind of tune did you get? no offense but if your got a good tune you wouldn't have this problem
Old Jan 7, 2011 | 10:22 AM
z28 TPI's Avatar
Thanks badmoon47 I'm leaning more towards tuning myself since its 85 I'm gonna change to a higher baud rate ecm and go tuning. Thans for the advise.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
86IROC112
Aug 17, 2015 02:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
