Ported base pictures(check this badboy out)
Old Mar 9, 2011 | 09:57 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
In all seriousness, I knew my Supercharged 355 would want as much air as it could get and I didn't want to spend the money on an aftermarket base, just in case I switched intakes...
Old Mar 9, 2011 | 10:21 PM
Artisan's Avatar
Car: 89 Iroc
Engine: 350/Dart heads/hotcam/TPI
Axle/Gears: 3.45 9bolt
Re: Ported base pictures(check this badboy out)
It looks good, especially the head side. You did a nice job. You might be able to open the runner side a little more but overall I like what you did.
Old Mar 9, 2011 | 11:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I agree. As limited as the factory casting is, you did open it up quite a lot.
Old Mar 10, 2011 | 08:19 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Decided to leave the runner side a little thick because the motor will see over 20 lbs of boost...
As much as I'd like to take credit, I didn't do it. A friend of mine did...
Old Mar 10, 2011 | 08:37 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm contemplating doing the same thing with my tpi (using an aftermarket base), but I am not sure if the gains will be work it. Does opening up the tpi intake make a big difference with forced induction engines?
Old Mar 10, 2011 | 09:00 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Sure it will, theres a lot of meat on the stock casting which is good cause they need help. Did one yrs ago took it to the extreme never got to use it. Changed hands a few times on another forum heard it was used but never got the results sure would like to know who has it now.
Had almost 30 hrs in that sucker
Old Mar 10, 2011 | 09:04 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Looks nice. Should definitley help with all that boost ur running. Hats off to your buddy on the port job.
Old Mar 14, 2011 | 12:59 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks guys. Getting it on the engine this week. Can't wait to feed boost through it!
Old Apr 5, 2011 | 12:07 AM
385IN2005's Avatar
Car: '97 GTP
Engine: 385 sbc, 3.8 Supercharged L67 V6
Looks good! I port stock TPI bases all the time and I can tell you that there is a lot more material than people think. I'm going to flowbench one soon to show that these can be real competition for aftermarket bases.
Old Apr 6, 2011 | 03:35 PM
Artisan's Avatar
Car: 89 Iroc
I a looking forward to see the results!
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
z28_AJ
Aug 27, 2015 08:59 PM
89-S-dime
Aug 12, 2015 11:57 AM
mx127
Aug 10, 2015 08:13 AM
