Need some help/tips on 305 Tpi
Old Mar 17, 2011 | 12:05 PM
90_firebird's Avatar
I bought a 305tpi engine last winter. I want to rebuild the engine with alittle more horsepower than stock but i dont know how to go ahead and what parts i should buy to make this happen.
Old Mar 17, 2011 | 12:12 PM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
Re: Need some help/tips on 305 Tpi
alot of people are going to say this and i will be one of them but why build up a 305 when you could beuild a 350 for alot cheaper. I am building one right now and so far i am in the whole about 250 bucks. That is the 250 dollars 1990 corvette 5.7l block some free heads and thats just to start. would be alot easier and alot cheaper in the end
Old Mar 17, 2011 | 12:39 PM
JustCruzin's Avatar
Plus, read the boards lots of good info here, good luck with the build, keep us posted.
Old Mar 17, 2011 | 01:09 PM
Iam not like most people....My opinion is that everyone has a built 350 but hardly anyone has a built 305...My car isnt going to be a drag car or anything like that i just want a engine that has alittle more power than a stock 305. this car is mainly going to be a weekend car or for long highway trips.
Old Mar 17, 2011 | 03:42 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I understand what you are saying. You can build a mild decent performing 305 tpi motor that does what you are looking for. The big problem with the most 305's from the factory was the "peanut cam". A 305 with a 350 cam installed will run almost as fast as a 350 car. Personally, I would do a basic rebuild on your bottom short block of your motor and then add a set of World SR Torquer 305 Heads and a Crane 2032 compucam and call it a day. This setup will probably require little to no tuning and will really run great. If you like you can also upgrade your TPI intake manifold and runners with some nice Edelbrock pieces and you will have a nice performing car that it still great on gas and the highway. Enjoy!
http://www.summitracing.com/parts/WRL-042750-1/
http://crane.carshopinc.com/product_...d/15861/104224
http://www.summitracing.com/parts/EDL-3870/
http://www.summitracing.com/parts/EDL-3860/
Old Mar 17, 2011 | 05:34 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Im with burnout on this. If you're not looking for huge power, there's alot you can do with the 305.
Old Mar 17, 2011 | 07:21 PM
What size injectors should i get?
Old Mar 19, 2011 | 02:16 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Injector size depends on expected power output. I don't remember the equation but you can find it on TPIS's website. You will need to have some idea of expected HP. Injector output is also affected by pressure. Once you arrive at a lb/hr nozzle size, you can adjust actual output by tweaking pressure. Of course if you make many changes in the motor, you'll want to retune the ECM.
Old Mar 19, 2011 | 03:07 PM
RT66DAVE's Avatar
Burnout 88 is right on target for advice.
Old Mar 21, 2011 | 07:50 AM
If i bought the cam that burnout 88 suggested would i need different cam bearings than the stock ones i have in there now
Old Mar 21, 2011 | 08:05 AM
BlackNightRider's Avatar
Car: 87 iroc conti
Engine: 5.7 pro charger
Transmission: 700r
it would be a good idea to change them being if you are in there already then put new ones in when you upgrade things
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
