Car wants to die when I floor throttle
Old May 12, 2011 | 07:15 PM
Ericsxtnirocz's Avatar
When I floor the throttle the car wants to die first then after like two seconds it will regain power.recent full tune up,problem just started,any help greatly appreaciated.
Old May 12, 2011 | 07:21 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
Re: Car wants to die when I floor throttle
accelerator pump. had the same issue with my 74 chevelle.
Old May 12, 2011 | 11:39 PM
elpulpo's Avatar
is this happening when you stop and go or when its running(driving it),check egr valve
Old May 13, 2011 | 07:44 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Is the car carbureted or EFI? If carb, it's the accelerator pump. If EFI, it's the TPS.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
