Vapor Canister Details
Old Jul 24, 2011 | 04:04 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Can someone please explain the function of that little black canister that has always been chilling in the corner of my engine bay that I have paid no attention to :P
Also, I am wanting to delete it so I can run a firebird CAI kit for MAF cars. What needs to be done to properly remove the vapor canister and what negative effects if any will it produce if done properly?
Old Jul 24, 2011 | 06:28 PM
83Blackwidowz28's Avatar
Car: '91 Rs
Engine: 3.1 MPFI V6
Transmission: 700R4 B&M Shift Kit 2300-2500 stall 9" tq
Axle/Gears: stock 10bolt 3.23 gears
Re: Vapor Canister Details
The vapor canister has a charcoal filter at the bottom used to clean the vapors pulled from your tank. If you take it off you are gonna smell the fumes from the tank. You can delete but you will have to change your fuel lines and sending unit. If you just take it off and crimp the line you take the chance of vapor locking your fuel pump.
Old Jul 24, 2011 | 06:39 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
I went to Car Craft today and saw how the canister is supposed to be hooked up. No wonder why my car smells like fumes all the time.
Old Jul 24, 2011 | 06:58 PM
Car: 1985 Z28
I thought a vented gas cap would take care of the vapor buildup with no canister (?)
Old Jul 24, 2011 | 08:56 PM
Car: '91 Rs
Engine: 3.1 MPFI V6
J
The cap does release some pressure but not enough, too much and it wont pass emission test. There is actually a three part system for vapor release. Removing the canister will rarely cause vapor lock (it happens more often when that line is crimped), but you will notice a stronger petrol smell because the charcoal is not filtering it out. There is a vapor release valve that comes of the 4th line on the sending unit and if the diaphram stops working that will def. cause vapor lock.
Old Jul 24, 2011 | 08:58 PM
Car: '91 Rs
Engine: 3.1 MPFI V6
Haha thats how i learned there was a filter there and it need to be replaced
Old Jul 25, 2011 | 04:28 AM
Car: 1985 Z28
J
Are you referring to the "Vent" that is located near the driver side LCA?
Old Jul 25, 2011 | 08:19 AM
Car: '91 Rs
Engine: 3.1 MPFI V6
Its the located driver side next to the tank inside the fender
Old Jul 25, 2011 | 08:24 AM
Car: 1985 Z28
According to the research I've done on here, that is not a pressure release. Its a one way check valve that allows air INTO the tank to avoid vaccum.
Old Jul 25, 2011 | 09:38 AM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
Hey would you mind linking me to that article at car craft....I tried looking for it but I couldn't find it. I always smell fume's inside my car so Im interested to figure it out.
Old Jul 25, 2011 | 09:47 AM
Car: '91 Rs
Engine: 3.1 MPFI V6
That makes sense, when my tank was vapor locking i had to switch that out but the parts guy told me it releases it pressure... cool learn something new
Old Jul 26, 2011 | 09:35 AM
Car: 1985 Z28
Since I can't find a vented locking gas cap for my car, I'm just going to toss the canister and place some sort of valve on the fuel line. But I need to know of a valve that will only open to release pressure once it starts building up. I don't want something that's vented 24/7 allowing my gas to evaporate.
Old Jul 26, 2011 | 10:06 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I wouldn't toss it, keep it put up somewhere, that way if you sell the car in the future you can put it back like it's supposed to be.
When I bought my car it had a SLP cold air kit and no vapor canister to be found, someone even ran a dryer duct thru the fender out the bottom of the car trying to get more air. I ended up selling the cold air kit because I want my car to be stock.
Old Jul 26, 2011 | 11:40 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
If you look at the rubber line going into the canister, you'll see a round plastic check valve. That will hold the vapors until it reaches a minimal pressure from the tank, and then expel them where the line is routed. Take it off and blow into the one end and you'll see.
I deleted my canister and routed rubber fuel line from the sending until back up into the filler neck area. It terminates right above the gas cap so you wouldn't smell anything.
FYI, you will never find a true vented gas cap. They simply are not made to fit our cars.
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
