Intake manifold removal.
Old Jul 30, 2011 | 04:21 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I've removed all 12 bolts. Got the front lifted but the back is stuck. Is that little nut with a square head holding it down?
Old Jul 30, 2011 | 09:26 PM
Yager90IROC's Avatar
Car: 1990 Camaro IROC-Z28
Engine: Stock L98
Transmission: 700R-4
Re: Intake manifold removal.
Did you remove the distributor and the hold down bolt?
If you are sure you have all the bolts lightly tap the front of the manifold to break it free
Old Jul 30, 2011 | 11:43 PM
Mr Froman's Avatar
Yes. Dist is out. Was a pain to get the manifold to budge but with a pry bar on the front tab that sticks out I was able to carefully break it loose. The back is definitely held on by something else, you can feel it.
Old Jul 31, 2011 | 10:06 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i just torn my block down a few weeks ago..once you get down that far the only thing thats holding the manifold is the 12 bolts..... that is odd... unless the gasket is on there extremely tight or something.... i know when i first took the manifold off after 20 plus years of the intake being onto the block i had to pry it off it was almost as if it welded itself to the block...
Old Jul 31, 2011 | 10:38 AM
Johnnygeek's Avatar
Car: 1988 Formula
Transmission: TH-700-R4
Axle/Gears: BW 9 bolt 2.77
be carefull
the rear water passages may have fused to the heads and might break off if forced... I would tap with hammer and go slow
Old Jul 31, 2011 | 10:42 AM
Mr Froman's Avatar
I guess one of you broke into my garage and did the job for me.
I went out there this morning and it came right off. The gasket was like super glue.
Old Jul 31, 2011 | 10:50 AM
88fastgta's Avatar
yea i figured so..... being on the block warming and cooling for two decades made it like hell for it to come off... that happend to me also.....
Old Jul 31, 2011 | 01:18 PM
Mr Froman's Avatar
It's a pain. The heads are the same way right now. I'm fighting them today.
Old Sep 25, 2011 | 07:30 PM
Mulcreevy's Avatar
Car: 91 RS
Where is this tab that sticks out? I have a 91 RS and am having a difficult time trying to find a good pry point. I really don't want to use a screwdriver a and tap it into the rubber gasket, but righ now I cant see any other way.
Old Dec 23, 2011 | 07:56 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Sorry to hijack but its related... Im fixing a coolant leak..
I have all bolts out on my TPI intake manifold except the drivers side rear bolt. I havent been able to budge the darn bolt. I already even broke one T45 trying to get it out. The replacement T45 you can see is starting to twist.
The other bolts came out with not a lot of effort. I sprayed it with PB Blaster tonight and going to let it sit overnight. But if that doesnt work, Im afraid Im going to break the head off the bolt or do some other damage. It shouldnt be this tough to get out..
Any tricks I can try?
Old Dec 24, 2011 | 05:50 AM
Mr Froman's Avatar
Impact bit driver.
Old Dec 24, 2011 | 09:23 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
On some of my torx bolts for the runners and valve cover i used a sharp flat head bit and hammered it into the torx bolt pattern. That gave me some grip. Then i used a 1/4 inch socket adapter over the bit's head and a socket wrench and extension to get it off. Those torx bolts are stupid. I would replace all of them with regular head bolts.
Old Dec 24, 2011 | 06:25 PM
Diggler86's Avatar
Car: 86 TA
hey thanks for the idea.
i twisted two more T45's (supposedly stronger versions) and the bolt hasnt moved at all but started to strip the bolt. i pounded in a T47 and that thing is twisting also. once it twists then you can get any torque.
maybe i can figure a way to pound in a flat head or other type bit as you suggest..
if its in this tight is there any way im going to do something like crack the head if i keep trying and take it out?? i dont want to be in a worse situation at this time..
thanks..
Old Dec 24, 2011 | 07:19 PM
ninetyone's Avatar
Axle/Gears: 3:42
I told you insert a flat head bit into a 1/4 adapter. The back of the adapter should fit any 1/4 socket wrench,but instead use a socket extention. Preferrably 3/8 size. In order to do this you will need a 1/4 to 3/8 drive adapter also. Then hammer the end of the extention with a hammer until you feel the flat bit making its indentation into the bolt head.
Old Dec 25, 2011 | 02:54 PM
Diggler86's Avatar
Car: 86 TA
well just tried that and the bit broke within half a second. so now ive also got a piece of bit lodged in the head of the bolt.
only other thing i can think is to use a dremel and slot the entire bolt head and try to find something like this that is a large flat head:
http://www.ebay.com/itm/Black-Decker...-/400103007945
Old Dec 26, 2011 | 05:23 PM
Z28NZ's Avatar
Car: 85 Z28
Engine: 355 Vortec TPI
Axle/Gears: Stock
Had the same issue myself on 3 of the torx bolts.Got 2 out 3 out by welding with a tig a half inch drive socket to bolt head of about 12mm size using eutectic wire and let fully cool down naturally and they came out good. the 3rd was at the water jacket hole and sheared the head off but didn't matter as all others were out and manifold came off it ok. Got the stub out with a sharp rap with a large hammer and a small stilson wrench.Think I destroyed 3torx bits before i went down this track. Now using stainless steel socket head cap screws and antiseize.
Old Dec 26, 2011 | 07:01 PM
tmoble's Avatar
antiseize......
Old Dec 26, 2011 | 07:37 PM
Diggler86's Avatar
Car: 86 TA
antiseize would have helped 26 years ago...
FINALLY i got it out, believe it or not i used a dremel cutting wheel to trim it into a hex head shape and fit a 15mm over it. once that was on it didnt actually take too much effort to get it off.
additional questions, i realize there are not water passages on my manifold, but what is all this crap in those rear two ports? it looks same on the manifold side. should i knock this stuff out? its hard crusty stuff. just bc its a dead end for any coolant junk?
also, should i clean the intake ports, theres a lot of black deposits, but i dont want the crud to go back into the chambers which look surprisingly clean..
attached pics. thanks..
Attached Thumbnails Intake manifold removal.-2011-12-26_15-45   Intake manifold removal.-2011-12-26_15-44
Old Dec 27, 2011 | 12:51 AM
inkedbass's Avatar
Hijacking as well.
The same stuck the hell on bolt snapped on me. Looks like I have 7 threads left in the block, and about 1/2-1 inch sticking out. Any good ideas to get the damn numb out without cracking or warping the block?
J
Old Dec 27, 2011 | 12:59 AM
Diggler86's Avatar
Car: 86 TA
something like this might work (but ive never tried one)
http://www.amazon.com/Titan-Stud-Pul.../dp/B00265M8N4
Old Dec 27, 2011 | 01:40 AM
inkedbass's Avatar
We'll give that one a shot.
J
Old Dec 27, 2011 | 07:21 PM
Diggler86's Avatar
Car: 86 TA
ok i got most of the junk out of the head port and manifold....
however, it seems to have corroded the aluminum manifold and it created a slot on the port to the outside... ironically the junk was stopping another leak. so this wont seal properly with the new gasket. pic attached..
can i get away with some silicon in that area? and/or silicon every port now as well? or am i looking at having to ebay a manifold?
Attached Thumbnails Intake manifold removal.-2011-12-27_16-31
Old Dec 27, 2011 | 08:16 PM
Z28NZ's Avatar
Car: 85 Z28
Axle/Gears: Stock
I think that corrosion is a litte beyond silicon rubber, you could get it welded up but it probably cheaper to start again with a second hand manifold that has less corosion issues.
Old Dec 27, 2011 | 09:49 PM
Diggler86's Avatar
Car: 86 TA
i think you're right. just tough to come to terms that my weekend project has become a week already and about to become even more.. thanks for the reality check..
Old Dec 27, 2011 | 09:52 PM
ninetyone's Avatar
Axle/Gears: 3:42
Probably find a used tpi lower manifold for like $50
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
