do i need fuel vapor canister solenoid
Old Aug 5, 2011 | 12:40 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Do i need the fuel vapor canister on my 305 tpi? if not i would like that extra room and to plug in some stuff at the trottle body where the 2 hoses are and if i do need it can i connect the 2 hoses that go into the trittle body into only one hose goin to the trottle body so i could possibly shoot fuel in the other for my nitrous?
Old Aug 6, 2011 | 09:41 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: do i need fuel vapor canister solenoid
Don't know the answer on your nitrous question, but the fuel canister I think is necessary. It provides a vent for the gas tank, and allows the fumes to be burned. Without it, you will get high pressures inside the tank and will have a gas smell in the garage ( and even while you drive).
Old Aug 6, 2011 | 10:06 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
ok thank you now just seeing if anyomne has the answer to can i just conbined the 2 vacuum lines
Old Aug 6, 2011 | 07:08 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
you can get rid of the canister if you use a vented cap... thats what i did...
Old Aug 6, 2011 | 11:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by 87hellbird
Just seeing if anyomne has the answer to can i just conbined the 2 vacuum lines
Don't have two vac lines on pass side of TB
Two different ports on the TB
One has vac ( in ) and other has air supply (out ) to CCV system
Old Aug 7, 2011 | 05:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There are 2 vac lines running from a plastic valve that runs to the canister. One goes to the TB, the other directly to intake vacuum under the plenum. There are 2 lines for a reason, other wise 2 lines wouldn't run side by side. Not sure what the reason is though.
Old Aug 7, 2011 | 10:10 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Two different systems
The big line to TB vac port is tank vent line from canister.
The small line is a vac line that operates the vac valves on tank vent line.
OP is talking about the 2 ports on pass side of TB.
One goes to canister as above.
Other goes to rocker cover for CCV.
Old Aug 8, 2011 | 12:55 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
i have never heard of a vent where do you get them for how much? or did you build it?
Old Sep 11, 2011 | 04:35 PM
mcb55-210's Avatar
So, WILL a vented cap make it possible to remove the fuel vapor canister from the system?
Old Sep 11, 2011 | 05:20 PM
mcb55-210's Avatar
Wait-I just finished reading more of the threads on this same question, and do not want to open another can of worms! I am installing a TPI engine from a totalled '85 IROC in my '55 Chevy, and was just wondering if it would be possible to leave it off. Don't want fumes, don't want to insult Mother Nature if I don't have to, but also don't want to use this canister if I don't have to. Will keep researching, but if you can give me any guidance, it would be greatly appreciated.
Old Sep 11, 2011 | 05:56 PM
darbysan's Avatar
The TPI system, with the return line to the tank, will cause considerable pressure inside the tank. You will need some way to vent that pressure. You may already have it if you are using the '55 tank. I seem to remember a vent line on the top of those tanks that came out to the filler inlet. Something like that is what you will want. Vented gas caps, at least on later cars, don't vent until you start to open them. Seems like a mis-named part, don' it. Caps made for your '55 might be vented to atmosphere- just don't know.
You can run it without any vent- I did for several months until I found my pinched line. Just be careful and don't fill it up- the pressure will later push gas back out the filler inlet. Also be aware that enough pressure can build up to split a gas tank seam.
Old Sep 13, 2011 | 04:42 PM
mcb55-210's Avatar
I will be running a Spectrum tank designed for a fuel injected engine. I only see two lines coming out of tank-supply and return. Would a vented cap suffice, or should I run with canister?
Old Sep 13, 2011 | 06:43 PM
darbysan's Avatar
If you are running TPI, then you need a sender with 3 lines- Supply, Return and Vent. I don't think a vented gas cap will work for you, as they don't vent until opened ( according to the Stant website). Even with 3 lines on the sender, the Stectra tanks have trouble venting when filling, so many add another vent line from the tank to the top of the filler neck for filling purposes.
Personally, I would not run without the canister. Otherwise, you will be dealing with gas fumes, which are not good in an enclosed garage. You may also split a seam in the tank if the pressure builds high enough.
Old Sep 13, 2011 | 07:01 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
you can drill a couple holes in your cap.... search its on here somewhere.... I have been running the modified cap on my TPI for a year with ZERO issues.... and this is in the southern heat...
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
TheExaminer
Aug 26, 2015 04:59 PM
