a/c delete pulley - why?
Old Sep 26, 2011 | 07:21 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
I know i must be missing something here, why would someone go with a a/c delete pulley? couldnt you just get a belt for the motor without a/c?
Old Sep 26, 2011 | 09:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: a/c delete pulley - why?
https://www.thirdgen.org/forums/faq-...lete-smog.html
Because when the factory didn't install A/c they used the pulley in place of the compressor
so same belt
http://www.summitracing.com/parts/NAL-10055890/
Old Sep 28, 2011 | 10:34 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You can and it's much cleaner. However, I found the a/c delete belt length given (eg Rock auto) is too long. I needed a 1/2 inch shorter. Measure it with string and get just what you need.
Old Sep 28, 2011 | 11:12 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It makes using the belt tensioner easier.
You can delet the whole pass side bracket if you make a adjuster for your alt. Use a super short belt. Its a bit of fab work but it cleans it up.
Old Sep 28, 2011 | 01:10 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i would love to delete the whole passenger side bracket......
Old Sep 28, 2011 | 02:21 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I had a friend do it on a Z28. You could use a turnbuckle mounted to the alternator and use that to adjust the tension on the belt.
Old Sep 28, 2011 | 07:51 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/engi...-question.html
Old Sep 28, 2011 | 08:10 PM
88fastgta's Avatar
i want to try this but im not really sure what to buy or what belt to get or anything..... that whole bracket is basically useless because i just have a ac delete pulley and i bypassed the smog altogether with a shorter belt and different routing system.. so i dont even have a smog delete pulley...
Old Sep 28, 2011 | 10:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
im not really sure what to buy or what belt to get.
You can test it without buying anything .
Just run a piece of string around the proposed setup to check alignment and any clearance problems.
Allow for the fact that the Alt has to have a small amount of outboard movement to give belt tension.
If you are happy, position the Alt at end of inward movement and use the string to get required belt length
FWIW.
There are guys on the Vette forums that did not swap their pumps and say they have no problems running the rev rotation pump in opposite direction
The vanes on the impeller are straight so they move coolant regardless of direction turned
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
