89 IROC problems
Old Oct 10, 2011 | 09:56 PM
cdiedrick's Avatar
Car: 89 IROC
89 IROC problems
I have an 89 IROC with a miss I am unable to diagnose. It has a new cap, rotor, plugs and wires. It isa350 TPI and still has amiss. Could this be an injector or wires? I even put the old cap back on, and still the same problem. HELP PLEASE!!!!!!!!!!!!!!!
Old Oct 10, 2011 | 10:11 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Re: 89 IROC problems
Double check your firing order and wire placement?
Old Oct 11, 2011 | 08:46 AM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Since you did the cap/rotor/plugs/wires, you should take an ohm meter to the injectors. Any reading under 12 and the injector coil is shot. If all readings come back good when the engine is cold, check the resistance on them all when the engine is hot. The injectors in your car are notorious for shorting and causing missing.
If you find one or more bad, get in contact with Southbay Fuel Injectors. Stellar customer service, and prices and products that cant be beat.
Let us know what you find!
Old Oct 11, 2011 | 07:20 PM
mlopezformula's Avatar
Car: 1989 Firebird Formula
Engine: LB9 305 tpi
Axle/Gears: 3.43
Yup check your timing, ignition system, and the injectors i got a used set for 50 bucks 6 months ago and now one is probably staying open.
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
