Fuel Pressure?
Old Oct 21, 2011 | 11:43 AM
iinversion's Avatar
Car: 1987 IROC-Z (G92)
Transmission: M5
Fuel Pressure?
I have a 1987 Iroc-Z 305 TPI. (G92 package).
Mods that I can remember:
3.48 Gears
65mm BBK Throttle Body
K&N Cold Air Intake (Stock dual intake that came with G92 package)
Dynomax Cat-back Exhaust
Edelbrock Shorty Headers
CraneCam Mild Camshaft -
Link to Camshaft: http://www.cranecams.com/product/car...detail&p=24201
Now my question is, where should the fuel pressure be at? It has an aftermarket fuel gauge/regulator I'm just wondering what I should be setting it at..
Old Oct 21, 2011 | 12:33 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Fuel Pressure?
i have mine set to 41psi with vac. line hooked up. about 47psi with it disconected (simulation of wot).
the magic number i think is 43.5 psi but cant remember if its with vac. line disconected or not?? These injectors are designed around this pressure.
Old Oct 21, 2011 | 07:28 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
hmm.. I looked at the gauge while the car was running.. seems to be somewhere around 37psi or so. Too low?
Old Oct 21, 2011 | 08:16 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: Fuel Pressure?
37 psi with line connected is about stock. Adjust to about 44 psi with vac line connected or the easier way would be to adjust to about 50 psi with it disconnected and that will set you near 44 psi with the vac line connected.
Old Oct 21, 2011 | 09:11 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
Alright will adjust it tomorrow thanks for the info.
Old Oct 23, 2011 | 11:19 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Fuel Pressure?
for the guys running a psi guage! after i turned my car off yesterday i noticed my fuel pressure dropping down gradually to 10psi over about 2min period. in the past my pressure would hold strong for like a half hour.
does this sound normal?
Old Oct 23, 2011 | 12:50 PM
burnout88's Avatar
Car: 88 IROC
Re: Fuel Pressure?
No that sounds a bit quick. You may have injector that is starting to leak. My will hold pressure for hours after I turn the car off.
Old Oct 29, 2011 | 07:27 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
I finally had a chance to go out and adjust the fuel pressure. First of all, the Cranecam AFPR is a PAIN to adjust. I had to loosen the bolts on the runners that bolted it into the plenum and pop the back end of it up so I could even turn the screw because the nut was stuck on the plenum.
Anyways.. I just adjusted it a little, bolted the runners back on tight to the plenum and it's now at 41-42 PSI ish up from 37 PSI at idle. At first it smelled a little gassy from the engine, but it went away pretty quickly. I took it out for an aggressive drive & smelled no gas whatsoever in the car, but I can smell gas when I'm behind the car around the exhaust. I just wanna make sure I don't run rich.. so should I still go bump it up to 44 PSI?
Old Oct 29, 2011 | 07:41 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: Fuel Pressure?
The fuel pressure is only one part of the whole air/fuel delivery and combustion system.
To properly tune your car, you are going to need to get a EPROM burn for your car and setup.
Old Oct 29, 2011 | 08:53 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
Hmm. how much PSI can the stock injectors handle anyways?
Old Oct 30, 2011 | 09:58 AM
bartman0916's Avatar
Re: Fuel Pressure?
My Return line was jammed up when I bought it, and blew out fuel pressure diaphragm when i put a gauge on it was running 75 psi- lol - not good but just gives you an idea they are pretty tough.
Old Oct 30, 2011 | 12:42 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
Damn, 75 psi? Well then I won't be worried about that.. good to know.
Regarding this.. When I bought the car the owner gave me a chip that he bought and never used with the car. Here it is:
http://www.summitracing.com/parts/HYP-127052/
Should I even consider using this thing?
Old Oct 30, 2011 | 01:49 PM
Guest
Guest
Posts: n/a
Re: Fuel Pressure?
38 psi, stock at idle.
Old Oct 30, 2011 | 03:57 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Fuel Pressure?
i would try using it! i know a few members dont like "general mail order tunes". this chip will not tune to its full potential but should be better then the stock one. you have a mild cam right?
Old Oct 30, 2011 | 04:00 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
I'll go ahead and give it a go then! In the instructions it says to use 93 octane? .. is that normal? But , yea I have a mild cam. Here is the cam I have:
Old Oct 30, 2011 | 04:03 PM
Impaqt's Avatar
Re: Fuel Pressure?
The chip must have a pretty aggressive timing curve then. higher octane gas wont knock as much as standard 87 octane.
Old Oct 30, 2011 | 04:08 PM
iinversion's Avatar
Transmission: M5
Re: Fuel Pressure?
Yeah I have not a clue about the chip. He said he got it with the car.. I looked it up looks like it matches this car, but I'm assuming it is made to work with a all factory motor. Ah well, so I suppose I am going to give it a go and see how it turns out. I'll use 93 octane just for testing purposes when I do it though.
Old Oct 30, 2011 | 05:00 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: Fuel Pressure?
you should double check with the tuning board on tgo, im no expert when it comes to tuning.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
