cranks to much before starting when hot
i have 91 z l98 , when its cold its starts right up, sometimes i think it starts to fast. but when its t running tempature and i try to start it up, its cranks alot before starting. its a healthy crank. i thought i could of been a leacky injector, but am i wrong?
Car: 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 limited slip
Re: cranks to much before starting when hot
turn the key to on but not start. give it a few seconds then crank it over and see if it starts right away or the same. not uncommon for this to happen to older fuel injected cars
Car: 1986 Irocz
Axle/Gears: 3.25:1
I think the most common cause is injectors leaking fuel into the cylinders after you shut the engine off.
If this is the case then check your oil for fuel contamination, because fuel in the oil can eventually trash your bearings.
With leaky injectors you can shut the engine off hot, then start it right back up within a minute or two and it starts just fine, but after sitting 5 or 10 minutes it cranks for a while before starting. After an hour or more of sitting it starts fine once again, even if still hot.
You might want to check the resistance on the injectors both hot and cold. The stock injectors on these cars are extremely prone to coil failure. They may ohm out fine when they are cold, however it is common for them to shut down when hot.
www.southbayfuelinjectors.com
516-492-6504
516-492-6504
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
I'm not familiar with TPI cars, but what about your fuel pressure regulator? easy cold starts, hard warm starts sounds like the FPR.
-OSS
-OSS
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've never had a fuel pressure regulator cause that problem. I have had it happen from a bad coolant temperature sensor. If that goes bad, it tells the computer it's -40 outside. When the car is cold it can still start, but if it's warm, it floods it.
The ohms on the injectors should be a minimum of 12.0 or above.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 1roc89z28
have to pull the fuel rail again...
how if the gas lines prevent me from lifting the fuel rail?
