Any reason why my SES light staays on
Old 11-26-2011, 03:21 PM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
My ses lights stays on all the time..no codes only 12..even tried to reset it.but when I ride around light will turn off and car runs bad.
Old 11-26-2011, 11:15 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Any reason why my SES light staays on
could be a bad ecm, also what happens when you first turn the key on,just to the on position? should get a quick flash of the ses light and then it should stay solid.
Old 11-27-2011, 01:37 AM
[Yes does all that....hopefully it is
QUOTE=ninetyone;5105165]could be a bad ecm, also what happens when you first turn the key on,just to the on position? should get a quick flash of the ses light and then it should stay solid.[/QUOTE]
Old 11-27-2011, 02:02 AM
RicerEater78's Avatar
had a similar issue with mine. be sure to watch the codes flash for a period of time. I was always told that it would flash 12, the stored codes, then 12 again but that's not what happened on mine
Old 11-27-2011, 02:24 AM
A bad ecm might explain wh y my fan stays on all the time even when I just turn the key over not startin
Old 11-27-2011, 03:59 PM
ninetyone's Avatar
Axle/Gears: 3:42
ok, that sounds like limp home mode. Or field service mode. Could be a bad chip. Light does blink quickly and then turn solid?
Old 11-28-2011, 09:17 AM
Yea blink fast then stays on...I'm getting my new ecm intoday so hopfully its just the ecm...does the fan stay on all the time when its in limp mode...
UOTE=ninetyone;5105726]ok, that sounds like limp home mode. Or field service mode. Could be a bad chip. Light does blink quickly and then turn solid?[/QUOTE]
Old 11-28-2011, 11:08 AM
ninetyone's Avatar
Axle/Gears: 3:42
yes
Old 11-28-2011, 11:09 AM
ninetyone's Avatar
Axle/Gears: 3:42
could still be a bad chip tho.
Old 11-28-2011, 05:10 PM
Alright got the ecm in today,put it in and still the ses light stays on so I drove around the block and drove a lot better wit all power and performance then turned off the car,restarted it and the car ran like crap with a bad lope to it..so prom chip might be bad then...
Old 11-28-2011, 05:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
fan still running all the time?
Old 11-28-2011, 05:32 PM
Yes so I looked at the fan and noticed a red wire coming from fan harness so I think someone wired the fan to stay on all the time...I did noticed on my ecm harness a Orange wire that looks as it has slipped out the ecm connector but I don't wanna try tobplug it up to anything and cause more problems..
UOTE=ninetyone;5106798]fan still running all the time?[/QUOTE]
Old 11-28-2011, 05:39 PM
ninetyone's Avatar
Axle/Gears: 3:42
orange wires at your ecm are fuel related.
Old 11-28-2011, 05:52 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would guess, the maf is acting up now.
Old 12-05-2011, 03:23 PM
Fixed the problem..MAF was acting up when heated or something.car runs good now
Cleotiz
01-06-2018 08:56 PM
TheJoeY88
12-31-2016 07:30 PM
tc7761
08-30-2015 09:45 AM
eightsixseven
08-14-2015 03:09 PM
Omega
08-10-2015 12:46 PM
Quick Reply: Any reason why my SES light staays on
