TPI and Wiring Converting?
Old Nov 28, 2011 | 10:52 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
Is their a way to get rid of the stock ECU and change to a aftermarket one like Holley's for TPI. I am trying to get the EGR, planning on using a turbo or supercharger and wanted get away from all the computer stuff to time the motor. Also I am sick of not being able to change something in the wiring with screwing something else up. Would like get rid of the chip in the key while I am at all of this to.
Old Nov 29, 2011 | 12:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI and Wiring Converting?
Originally Posted by 91copo
Is their a way to get rid of the stock ECU and change to a aftermarket one like Holley's for TPI. wanted get away from all the computer stuff
I don't see the difference; with the Holley EFI you are still going to have a computer and wiring
If you don't want a computer and wiring; put a carb on it.
Solves all your problems inc chip in the key with one stroke
Old Nov 29, 2011 | 11:49 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Sounds like you need to get into chip burning. Keep the stock tpi stuff
Old Nov 29, 2011 | 11:50 AM
ninetyone's Avatar
Axle/Gears: 3:42
the idea behind boosting is getting great mileage at part throttle ,but having lots of power at WOT. Why go carb?
Old Nov 29, 2011 | 11:52 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
reprogram or dynamicefi ebl p4
Old Nov 29, 2011 | 06:26 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by ninetyone
Why go carb?
The OP's question is a jumble.
He apparently wants
a aftermarket ECM but wants to " get away from all the computer stuff and wiring"
delete EGR
forced induction
delete VATS.
Carb is a quick and dirty fix for most of those
Old Dec 1, 2011 | 10:03 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
I just want to do this car right so I don't have to worry about electric problems like I've heard about. All I want is the EFI with the other electronics if ya get what I'm saying. Also, is there a way to get rid of the chip in the key, I have heard those will go bad and hurt performance and cause starting issues.
Old Dec 2, 2011 | 08:17 AM
ninetyone's Avatar
Axle/Gears: 3:42
Well, if ain't broke , don't fix it. I got my vats deleted when i got my new chip made. There are also kits on ebay for bypassing.
Old Dec 2, 2011 | 10:36 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
thanks checked into the vats delete and it was helpful. how do you tell what chip is in the key?
Old Dec 2, 2011 | 10:41 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
I would like to stay with the TPI just have the bare minimum so it's idiot proof (i got three brothers). I would like to be able to time the motor by the distributor not go through the ecu.
Old Dec 2, 2011 | 11:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
If you mean set the initial (baseline) timing, the ECM is actually disabled to set it.
Once the ECM timing control is disabled, setting the timing is the same as a non-ecm controlled engine.
The use of the engine will determine how much computer control (sensors) you need, thereby reducing wiring. The more you dumb it down, the more fuel it's going to use. There's always a trade off.
Old Dec 5, 2011 | 09:27 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
i read elsewhere that if you do try to time the motor by the distributor it will be lying to the ECM and hurt performance?
Old Dec 5, 2011 | 09:38 PM
ninetyone's Avatar
Axle/Gears: 3:42
You set the timing by unplugging the EST (the computer controlled "advance"). How would the distributor be "lying"? If you advance timing, you can get better performance most of the time, just like any other car.
Old Dec 7, 2011 | 06:17 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
Okay, thank you for setting me strait there.
Old Dec 7, 2011 | 06:29 PM
91copo's Avatar
Car: '91 B4C
Engine: 5.7L TPI
Transmission: 4L60
Here's another question, this is a '91 B4C car with TPI 5.7 and Th-700-R4, i was wondering if the ECMs in these cars have a different tune than the other non B4C Camaros?
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
