Strong smell of gasoline
Old Apr 24, 2012 | 11:48 PM
806camaro's Avatar
Car: 1990 IROC
Lately I have noticed a strong smell of gas while driving around town. I have a 1990 camaro IROC with a 305 TPI. What could be the cause of this? I'm new to Fuel Injection. This smell of gasoline is a recent issue that just started happening.
Old Apr 25, 2012 | 12:09 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Strong smell of gasoline
Mine did this as well, but there was never a real problem. I've noticed that since I took my air inhjection system off that is is noticebly better, I also gutted my air boxes and that helped, I barely smell it anymore. Yours could be a gas leak(s), clogged lines, bad tank vent, not enough air through the intake, bad evap canister, many, many things. I'd see if you need a tuneup if you're not leaking any gas and have checked your gas tank vent.
Old Apr 25, 2012 | 06:25 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It could be anything. A common problem is overheated fuel in the tank. Could also be as simple as a porous rubber canister vapour line. The nice thing about fuel is that it's easy to find a leak by using your sniffer.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RS Reaper
Oct 17, 2018 07:52 PM
Dwayne614
Sep 29, 2015 11:05 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
