Runners, intake??
Old Apr 27, 2012 | 12:49 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
Transmission: 700R4 Transgo 2-3
Axle/Gears: 10 bolt 4.10s
Runners, intake??
I have been searching all kinds of sites and I can't come up with an answer. I got a L98 with a lt1 cam, 28# injectors, short tube hookers, 3" pipes into a flowmaster no cat, k&n filters, built trans with a 2400 stall.
I am looking for some more power, but I want to keep it around 500 bux.
I am thinking that some larger or siamesed runners and a ported plenum and some 1:6 rr's are the way to go with what I have. I have looked into spending some more money on a First intake or a HSR, but I am not wanting to spend that much.
I guess my question is, is this a good route to go? Maybe later adding a Edelbrock base? My plans are for a small supercharger in the future like a P-1SC. I don't really want to waste money if I'll will have to swap out the intake after going with the forced induction. I am not looking for a lot of extra power. I would be happy with 10-15hp with my plans now and 50-60hp with a sc.
Old Apr 27, 2012 | 12:51 AM
conlinj's Avatar
Re: Runners, intake??
the HSR will give you way more that the edelbrock base and any runner combo will for far less money
Old Apr 27, 2012 | 01:01 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
If I could find a HSR with rails and stuff for less then $500 that would be the way I would go. Every where I have been looking it is around a grand.
Old Apr 27, 2012 | 01:07 AM
conlinj's Avatar
what is your base timing set to? bumping to 10* will make a nice difference and its free
Old Apr 27, 2012 | 01:08 AM
conlinj's Avatar
For that price you could also buy a nitrous kit...
Old Apr 27, 2012 | 01:10 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
I am 8* on timing, and I am not wanting to go with nos.
Old Apr 27, 2012 | 01:13 AM
conlinj's Avatar
watch the classifieds, HSRs pop up fairly often
Old Apr 27, 2012 | 01:34 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
If I could find a HSR for the price I am looking to spend I would go that route. My question still is, would some different runners, ported plenum, and some 1:6 rr's give me a little more power and be suitable for forced induction?
Old Apr 27, 2012 | 05:33 AM
conlinj's Avatar
it would but runners are 450, and rockers are 250. That's about the same price as a stealth ram
Old Apr 27, 2012 | 07:00 AM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I bought roller rockers from summit for 175..
Old Apr 27, 2012 | 11:40 AM
conlinj's Avatar
What brand are they?
Old Apr 27, 2012 | 11:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
These I think are the cheapest self aligning ones ever. Not sure if there any good but there dirt cheap.
http://stores.thunderchickenauto.com...%2C/Detail.bok
Old Apr 28, 2012 | 02:11 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
are they the narrow ones?
Old Apr 28, 2012 | 02:23 AM
conlinj's Avatar
remember you get what you pay for, a quick google search will show lots of broken proform/summit/jegs brand rockers, and the rockers from thunder chicken require 7/16 studs
Old Apr 28, 2012 | 11:16 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
Good call. I was wondering about the quality of the tose brands.
Old Apr 29, 2012 | 11:26 AM
BadSS's Avatar
If you are comfortable with a grinder, look for a set of used SLP runners, grind the dividers to about the halfway point and port your stock plenum and base. Just grinding down the EGR wall and lip at the runner entry on the base does wonders for the TPI. With your cam and injectors, a good custom tune on the chip would help as well - especially after porting.
Last, but not least, if you have the dual entry exit Flowmaster, that is probably the worst flowing muffler available for these cars. A swap to a DynoMax Ultra Flow Welded muffler 17227, especially after doing the intake, plenum, and SLP runner porting should give you a noticable gain.
Depending on the deal you can get on the SLP runners,,, and whether or not you can do your own porting and programming,,, you might be able to do all this for around the $500 mark.
Old Apr 30, 2012 | 08:42 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
off topic but badss im running flowmaster 80 series on my car right now... how much is that holding me back...
Old Apr 30, 2012 | 08:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
On my bolt on car, going from 80 series flowmaster 3" catback to a custom straight thru tube muffler in the I pipe, I gained 0 in the 1/4 mile....no noticeable difference but sound.
Old Apr 30, 2012 | 10:57 AM
BadSS's Avatar
Back in the late 80s when I was tweaking a number of these cars, I wouldn't see any difference in ET between the stock muffler and replacing it with a 80series Flowmaster - while it sounded different,,, it didn't require enrichment at all. However, replacing the stock muffler with a single in single out Flowmaster required a little enrichment and would drop ETs right at a tenth. There was typically around a 100rpm increase in shift-point also.
The 80series only flows around 480cfm IIRC, not much more than a stock exhaust system. If you know how Flowmasters work, one look at the internals should turn you away from one.
Old Jul 26, 2012 | 05:35 AM
nr2180's Avatar
Car: 91 Z28
Engine: L98 TPI
What is the correct part number for a hsr for a 91 L98 with iron heads? All the ones I see like the 7540 say they are for 1987-Up with aluminum heads. Or the 7542 which is for vortec heads.
Old Jul 26, 2012 | 07:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you use the non vortec version which should be the 7540
Old Jul 26, 2012 | 07:33 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by nr2180
I guess my question is, is this a good route to go? Maybe later adding a Edelbrock base? My plans are for a small supercharger in the future like a P-1SC. I don't really want to waste money if I'll will have to swap out the intake after going with the forced induction. I am not looking for a lot of extra power. I would be happy with 10-15hp with my plans now and 50-60hp with a sc...
Don't waste money on an HSR then if your only planning on such minimal horsepower gains with the P1SC. Port your stock Tuned Port Injection system and advance your cam timing...
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
http://www.summitracing.com/parts/SCC-SCP1036BL/
running these worked good so far.
also what gears are you running.
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
