305 TPI engine jumpy and idles wierd
Old Jul 15, 2012 | 12:04 PM
TzP2I8's Avatar
Transmission: 5 Speed
At low rpms its real jumpy like it has a miss but it smooths out sometimes and when your cruising. Also the check engine light will come on for a couple minutes then shut off. Any ideas?
Old Jul 15, 2012 | 05:21 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Re: 305 TPI engine jumpy and idles wierd
have you pulled the code off when its there to see what it is ?
ive got a similar problem with my car at the minute and everything im trying isnt helping, i took all the spark plugs out today and cleaned them, cleaned the cap and rotor etc, took it out and its exactly the same, low RPM's if you touch the accelerator it feels like its misfiring and its all sputtery, but if you put your foot down more it takes off and is great, fine if im on a motorway but around town its pretty useless as its all over the place.
next thing to do is clean the IAC so ive been told, but i dont see how the IAC will help the car when its running anyway
Old Jul 16, 2012 | 11:20 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
The IAC controls how much air is allowed into the engine at idle. If it is dirty or in need of replacing, it can cause rough idle and low rpm problems.
I would start by checking/replacing it. If you are going to try cleaning it, I recommend seafoam. Spray seafoam all inside the throttle body, and make sure you get the hole for the IAC good. Then take a clean rag and clean the entire inside of the throttle body, including BOTH sides of the throttle blade. Depending on how dirty it was, you should see it smooth out quite a bit, and even notice a better throttle response as well.
Old Jul 16, 2012 | 12:21 PM
teal89iroc's Avatar
Car: 1989 camaro iroc
Transmission: Manual
Hey ya my car is doing the same sounds like it has a big cam in it real jumpy and sometimes stalls i changed plug wires checked fuel pressure vacuum leaks replaced iac with new one and still nothing running out of options did u figure out wat it is yet?!
Old Jul 16, 2012 | 05:36 PM
gta_knight's Avatar
Car: 1987 GTA
just searched for Seafoam as ive never heard of it before and you can get it here in the UK so i will get some of that if its supposed to be good stuff, it is in a a white can with red lettering yeah ?
Old Jul 16, 2012 | 05:54 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The problem here sounds less to me like an IAC issue and more like a lean condition. Maybe caused by unmetered air or a dirty or faulty MAF sensor. I would suspect injector faults except you say the engine runs well at higher throttle opening, which points away from fuel. A scan tool with datastream would allow you to see integrator and block learn and may point out a lean condition at idle.
Old Jul 17, 2012 | 10:34 PM
TzP2I8's Avatar
Today i just fixed it by adjusting the TPS. I noticed how you can move it and reliezed what the previous owner did was just put it on there straight. When I slightly pushed the pedal it was going WOT. Still needs adjusting but much better. Thanks for the input guys.
Old Jul 19, 2012 | 08:29 AM
gta_knight's Avatar
Car: 1987 GTA
my TPS is new and adjusted correctly so i know its not that on mine, after reading through other posts i think it might be my MAF, ive got a error code for the burnoff circuit failure so if the MAF is dirty it might be making the car run like crap ?
Old Jul 19, 2012 | 10:48 PM
TzP2I8's Avatar
Well today I found the real source cause it happened again. The MAF or MAP whatever it is that goes in middle of two piece intake was dirty. The previous owner had KN filters and over oiled them and oil was coated all over the sensor and intake and the engine was sucking it up. Cleaned it all up and cleaned the sensor and she runs normal now.
Old Jul 20, 2012 | 08:02 AM
gta_knight's Avatar
Car: 1987 GTA
I hope this sorts mine out then, i fitted my replacement MAF on wednesday but didnt have time to take the car out, so im hoping to take it for a run this weekend, i'll be able to tell in about 15 seconds of driving it if its fixed or not so fingers crossed !
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
