'89 305 TPI Cranks but won't Start.
Old Jul 17, 2012 | 05:43 PM
timmyd2434's Avatar
Car: '89 Formula Firbird
I have an 89 Formula Firebird that cranks over but will not start. I have check the fuel pressure to the rail and get about 45 PSI. I have check with a tester and get good spark. I is acting as if it is getting no fuel into the cylinder. I used a diode and resistor and I am getting a pulse to the injectors (I don't know if the amperage is high enough to open the injectors though.) I have Ohm'd out all the injectors and get 9 - 16 Ohms each. I am at a loss as to where to go from here.
At one point, it would run for a little while then shut off. I could leave it off for a little while, then it would start and run again for a short time. Now, it will no longer start at all. Once in a while, when I crank it over it will give one spurt as if to start. If I shoot ether, the car will run on the ether until its gone. So I am thinking the issue is fuel related, but I am stumped as to where the issue could be.
Old Jul 17, 2012 | 06:30 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: '89 305 TPI Cranks but won't Start.
89 is still MAF. Unplug the MAF sensor with the key off, then try starting the engine(this is default fuel mode). If it starts and runs, you have a MAF issue. You'll need to run through the MAF system tests to determine where the problem is. A rough explanation is that the MAF signal circuit should read about .5 volts KOEO, 1.6v at idle, 4.5v at WOT under load. The MAF needs 12v from the MAF power relay and a good ground on the MAF ground circuit.
Old Jul 17, 2012 | 06:40 PM
southbay08's Avatar
I do not know how many of your injectors ohmed out at 9, however they should not test any lower than 12ohm. You should think about replacing them as your coil/coils are "shot"
www.southbayfuelinjectors.com
516-442-4707
Old Jul 17, 2012 | 06:46 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
516-442-4707
That also! Lol
Old Jul 17, 2012 | 07:13 PM
timmyd2434's Avatar
I disconnected the MAF. It still will not start.
I know the injectors will probably need to be replaced eventually. However, they are expensive and I kind of want to replace them as a last resort. I am hoping it is something less expensive.
Old Jul 17, 2012 | 07:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
19's for a 305 or 22#hr for 350
http://www.southbayfuelinjectors.com...7&product=1500
http://www.southbayfuelinjectors.com...7&product=1502
Old Jul 20, 2012 | 12:48 PM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
Try unhooking your throttle position sensor on the side of your throttle body, I have had this issue with my 350 TPI and it was getting spark and fuel. As soon as I unhooked that sensor it started right up. Just a thought.
Old Jul 20, 2012 | 01:01 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
Old Mar 3, 2014 | 07:14 PM
crashcrtr's Avatar
Car: 1992 Chevy Camaro z28
If this is a MAF problem will you get an error code on your od2?
Old Mar 3, 2014 | 07:38 PM
timmyd2434's Avatar
Sorry everyone,
I did find out the trouble. There was one bad fuel injector on each side. It was odd for one on each side to go at the same time, but I guess it happens. They measured out good, but something must have been wrong. I replaced them and it fired right up. It still has problems, but nothing a little elbow grease and time won't fix. For those that are curious, the problems are a vacuum leak and injectors that didn't seat right.
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
