91 350 tpi map serious bog/stall issue
Old Aug 22, 2012 | 12:41 AM
RRUHL's Avatar
Car: 92 RS
Engine: 350 5.7 TPI from 91z28
Transmission: 700R4 transgo shift kit
Axle/Gears: 84z28 Disk brake with 3.23s
I recently swaped a 350 tpi speed density setup into a 92 rs "harness and ecm" timed it with esc disconected.... idles ok just replaced tps to rule that out im thinking my problem is vacuum related... you can rev it if you feather it but if you put your foot even quarter into it it sounds like its just sucking air and bogs hard until u take ur foot off if you push it further it will choke harder miss fire and die....I changed the fuel pump with the swap so i should have pressure really just stumped i ran heater tube and cruise into furtherst back niple map to midle and fpr into the bigger one more toward the front tryd switching map position with fpr same thing,,riped smog out and got the block off plate so i also have no egr seloniod for the stem under the tb i try blocking it off made it worse....i also have no sending unit for oil well a broken one at least was told this could be part of my prob cuz the ecm is shuting off the injectors??? going to get one tommorow but doubt its going to fix it.....also have the egr valve in still not sure if its stuck in the wrong position? any advice really apreciated thanks
Old Aug 22, 2012 | 02:57 AM
RRUHL's Avatar
Car: 92 RS
Re: 91 350 tpi map serious bog/stall issue
any ideas?????? any one??
Old Aug 22, 2012 | 05:43 AM
kevinc70's Avatar
Not sure one of my vehicles it was the intake manifold leaking and another issue was a clogged catalatic convertor.
Old Sep 2, 2012 | 10:07 PM
RRUHL's Avatar
Car: 92 RS
Ive been having tons of issues fixed my main one cracked fuel line in tank replaced and regulator tps idles strong now alil high can rev the h*** out oif it in park but as soon as i put it in drive instant kill or reverse is worse its like it slams in reverse and dies instantly....its a 91 L98 350 in a 92 rs changed the kick down cable and ecm with swap ohh speedo doesnt work guages fine idk if there related also rebuilt tpi and manifold any ideas one please??? really need to get it back on the road and am at a loss on ideas
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
