OMG Ticking FPR Problem Is Back!!!
Old Aug 31, 2012 | 09:47 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright folks I had a thread on here earlier this week about trying to trace down a mystery noise, and I had traced it down to my adjustable fuel pressure regulator.... It was ticking so loud I could hear it in the car, outside the car, it was bad...
Yesterday I swapped it back to the factory FPR, and the ticking went away...
Today it's back!!
What is causing my fuel pressure regulator to tick so loud??
The only thing I've read that might be a problem is, when I did my manifold swap and swapped over all my TPI parts, that there is a chance that the fuel rail/Injectors are too tightly bolted into the manifold causing the ticking to be more audible?
Does this make sense to anyone else? In 7 years of owning/working on a TPI vehicle (Not long I know ) I've never had this happen..
Thanks in advance.
Old Aug 31, 2012 | 09:57 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: OMG Ticking FPR Problem Is Back!!!
Thanks in advance.
I have never heard a FPR tick.. It is just a diaphragm and spring so it shouldn't make any strange noises. Usually the only thing that really ticks that I have found are my injectors.
Old Aug 31, 2012 | 10:04 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Yeah I've quickly found out that this isn't a common problem, searches don't help me out here..
I know it sounds crazy that a FPR would tick, but I've traced it down with a stethoscope.. The noise the FPR is making is the exact pitch, tempo, and sound that I'm hearing from inside/outside the car, just with a stethoscope it's a whole heck of a lot louder... (Of course )
I just don't understand what's making it tick? You're right the only thing in there is a spring and diaphragm, so my first guess with the AFPR was the plate that is pushed by the adjustment screw bouncing around... So i swapped the stock one back in = No adjustment plate... It stopped for a while and now it's back...
Is it possible that the fuel rail can be on too tight?
Reason I ask is that I've heard that the injectors shouldn't "Bottom out" on the manifold, but rather that they should sort of "float" on the O-Rings attached to them?
Old Aug 31, 2012 | 10:16 AM
ibmtech's Avatar
Car: 1987 IROC-Z
You are right.. The Injectors shouldn't bottom out.. They do get close to the bottom of the intake though. The only thing that holds them in place is the O-rings and the locking rings on the fuel rails..
Old Aug 31, 2012 | 10:31 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
So maybe I should loosen the fuel rail/injectors just a touch?
I'll just do that when I have the chance and report back
Old Aug 31, 2012 | 02:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I wouldn't loosen the fuel rail, if a leak occurs it can be bad news. Just make sure that none of the injector body is touching the rail or the intake manifold.
It is possible that the issue is in the fuel tank. Maybe the pump is picking up air and that is making the noise. May also be picking up air from a split fuel line or a bad turtle in the tank.
Remove the gas cap and listen there for any strange noises. Like bubbling or gurgling.
RBob.
Old Aug 31, 2012 | 02:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It ticks because there is a metal seat and a metal disc that opens and shuts. I'd say most of them do it. Some are just louder than others.
Old Sep 3, 2012 | 01:35 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
What makes this so irritating is that besides the noise, it didn't start until i swapped out my stock Manifold/Plenum/Runners/FPR out for my aftermarket stuff... The AFPR didn't tick at all on my other car, but yet the same exact setup on my new car ticks so loud I can hear it from inside the car??
Old Sep 6, 2012 | 05:23 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Check your pulsator
Old Sep 6, 2012 | 06:11 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Originally Posted by cuisinartvette
Check your pulsator
My what?
Old Sep 6, 2012 | 06:42 PM
TTOP350's Avatar
The pulsator is in the tank. Its supposed to help dampen the regulator and the pump pulsations.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
wayshegoes
Aug 17, 2015 12:00 PM
redmaroz
Aug 16, 2015 11:40 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
