Throttle Body Question
Old Jan 14, 2013 | 04:19 PM
makemm's Avatar
Car: 1988 Trans Am GTA
Engine: 305cui 5.0L
Transmission: 5 Speed Manual
Axle/Gears: Stock
Hi everybody.
I'm following this forum since 2010 and it is quite amazing. I learned so much from reading your posts here and now i have a question. I've read several post about throttle bodys and i'm a little bit confused.
Ok here is my situation:
I have a 1988 Trans Am GTA 305cui 5 speed manual transmission with almost 49000 miles on it.
Mods done so far:
Edelbrock Tubular Headers, 3" Magnaflow Exhaust, 180° Thermostat and a JET fanswitch, KYB AGX adjustable shocks, Eibach 1" Lowering Springs.
Currently working on the intake, Edelbrock Performer High-flow with runners, just polishing and gasket matching, no porting or siamesing because i don't change cams and heads. I must say that i'm not looking for super performance, just a little bit over stock that's all.
Now, my stock TB look ugly on the new intake and the cleaned Plenum and i wanna buy a new one but Summitracing only has 52mm and 58mm.
My question is: Will a 52mm TB work with my actual setup without problems ?
If i have to make changes to the PROM that's no problem because i have all the hard and software needed to edit and burn PROMs. Thank to TGO.
Many thanks in advance.
Regards
Old Jan 14, 2013 | 06:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Throttle Body Question
Originally Posted by makemm
my stock TB look ugly and i wanna buy a new one
Will work fine but most consider it a waste of $ on a basically stock engine
Maybe save some $$$ by spending some time cleaning yours up and then buy a fancy top plate for it?
http://www.ebay.com/itm/TPI-Throttle...46b69d&vxp=mtr
While you have it apart consider removing the ugly hose spigots from the IAC housing and then polishing the housing
Old Jan 14, 2013 | 08:31 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi everybody.
Just an FYI - If you have an air foil for your stock TB, it will not fit on the Summit TB's. The part of the TB that the air foil rests against is a different shape.
Old Jan 15, 2013 | 12:45 AM
makemm's Avatar
Engine: 305cui 5.0L
Axle/Gears: Stock
Hi
Thank you for the fast reply. Yes i know it's not cheap and i already have a plate. It's like spraying parfume on a pig. If a 52mm TB works it's ok i'm not looking for performance anyway. Should i gasket match the Plenum to the TB or just bolt on?
Regards
Old Jan 15, 2013 | 05:37 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Should i gasket match the Plenum to the TB or just bolt on?s
IIRC a 52mm TB bolts on without mods
you may want to consider the popular mod of taking out the EGR humps while you have everything apart
See
http://www.eecis.udel.edu/~davis/z28...um_marked2.jpg
Old Jan 15, 2013 | 11:11 AM
makemm's Avatar
Engine: 305cui 5.0L
Axle/Gears: Stock
Thanks for the advice.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
